JTK
$100 Site Donor 2025
I've had this trimmer for about 12yrs and it's been flawless for me. About mid season last year I noticed it would leave a little puddle of fuel at times and began to bog down and stall intermittently, but would restart.
First use this year, the stalling was obnoxious, but I didn't notice fuel leakage. Pulled the plug and it was very hot and dry. Yikes! I pulled and replaced the carb with a $12 eBay special. Buttoned it up today with the replacement carb and had fuel leakage when I primed it and it would barely run at all. Dry-ish sparkplug again..
Pulled the carb again to find a cracked fuel line, that was most likely my problem all along! This model uses a molded once piece black rubber fuel line/tank grommet assembly where the hoses are kind of ribbed/bellows style, so it hides small cracks if you don't inspect it closely.
Now waiting on a $15 fuel grommet assembly.
