Finally got my echo running good the last time I used it (carb adjustments) and now I went to use it the other day and it wouldn't start. The primer ball was empty, usually has gas in it, and when I pump it, I can see it suck fuel up the hose to the primer, but not into the ball itself and it used to do that. But when I remove the fuel cap, it releases pressure, so the ball seems to be working. I replaced all the fuel lines, the breather, the fuel filter, and the grommet in the tank last summer, and since it seems to hold pressure in the tank, I don't think there are any leaks. Any ideas?
