Patman
Staff member
Title is now changed, although I used the proper term of grade instead of weightGood idea for the mods.
I'm not sure I would do this, but it sounds like the HPL 40-grade PCMO would be good for use here from April through October.Reading this thread it's clear that the HPL PCMO 40 is not a standard 40 weight oil. As mentioned, due to the base stock used, it's more like a 20/25W-40 oil. That's quite different from a regular 40 weight, which doesn't flow as well when cold. It would be very interesting to have proper data on what the W test rating would be.
My general hesitation regarding these thicky oil threads is the unknown. Thick oil may force the bypass to open unexpectedly. Could it cause filter tearing? We just had a thread here where someone blew out an oil filter seal on a cold start. How does the thick oil affect the internal oil devices that employ the oil like hydraulic fluid, such as cam timing or cylinder deactivation systems? I just don't see the point of risking the unknown when multi grade 40 weight oils are available and common. This HPL does open the door to the possibility, but whether to use it is a person experience.
Is there anyone in the BITOG community going to buy some of this oil based on this, and other, threads? If so, what is the application and temp usage range?
That’s my stance as well. Basically, “why?” when totally suitable and fantastic options already exist that are more standard and easier for the consumer grasp at surface level.I am sure this is usable for pcmo purposes, but given that Any HPL product would be fine with an OCI so much longer than I would be comfortable with, with a cleaning capability and VII that doesn't leave anything to be desired, I am still unsure what is the appeal of a straight grade?
even for track purposes, would not we want an oil that looses less viscosity once it heats up, meaning a higher VI?
It's just playing games with SAE grading nomenclature. Pointless when No-VII 10w40 exists (and if you wanted to pretend that doesn't have a winter grade test result, you could call that SAE 40 too).Reading this thread it's clear that the HPL PCMO 40 is not a standard 40 weight oil. As mentioned, due to the base stock used, it's more like a 20/25W-40 oil. That's quite different from a regular 40 weight, which doesn't flow as well when cold. It would be very interesting to have proper data on what the W test rating would be.
My general hesitation regarding these thicky oil threads is the unknown. Thick oil may force the bypass to open unexpectedly. Could it cause filter tearing? We just had a thread here where someone blew out an oil filter seal on a cold start. How does the thick oil affect the internal oil devices that employ the oil like hydraulic fluid, such as cam timing or cylinder deactivation systems? I just don't see the point of risking the unknown when multi grade 40 weight oils are available and common. This HPL does open the door to the possibility, but whether to use it or not is a personal decision.
Is there anyone in the BITOG community going to buy some of this oil based on this thread? If so, what is the application and temp usage range?
Those are valid concerns for the most part.Reading this thread it's clear that the HPL PCMO 40 is not a standard 40 weight oil. As mentioned, due to the base stock used, it's more like a 20/25W-40 oil. That's quite different from a regular 40 weight, which doesn't flow as well when cold. It would be very interesting to have proper data on what the W test rating would be.
Thank you for the continued helpful replies.That’s why I’m a vocal proponent of Valvoline Restore and Protect despite the lackluster HTHS in the heaviest grade 5w-30 at around 3.2. Do I want more HTHS? Yes. Is it worth giving up Valvoline Restore and Protect cleanliness in the real world? Not in my view.
That’s a fairly close summary, although I do not recommend any Redline oil to friends, despite being a former user. I’ll try a more thorough “heirarchy of recommendation” in the form of a decision tree in a subsequent post because I’d like to have it be more precise.Thank you for the continued helpful replies.
So in your view, you'd either run (or say recommend to family or friends), if I was going to distill it into one line, Valvoline Restore and Protect 5W-30, a full SAPS Euro oil with HTHS >3.5 (we don't have GPFs here) or a very high quality oil like HPL with an HTHS >3.5, ideally closer to 4.2, if someone was willing to spend the money?
Red Line's Euro 5W-40 (link) packs an HTHS at a whopping 4.4. Seems like it would run very clean with its PAO and ester formulation.
Their regular 5W-30 (link) (non-Euro but still recommended for VW 502 and LL-01...so must have a Euro add pack??) has an HTHS at 3.7 even.
Sounds great!I’ll try a more thorough “heirarchy of recommendation” in the form of a decision tree in a subsequent post because I’d like to have it be more precise.
Before I get to my logic tree, some anchor points that underpin my thinking:That’s a fairly close summary, although I do not recommend any Redline oil to friends, despite being a former user. I’ll try a more thorough “heirarchy of recommendation” in the form of a decision tree in a subsequent post because I’d like to have it be more precise.
Man, I was in a meeting today for 3 hours with various tables, charts, or, as Bob Gates, ex SecDef, would call, "Death by PowerPoint."Before I get to my logic tree, some anchor points that underpin my thinking:
- I treat all vehicles as if they are out of warranty because warranty constraints exist to protect the OEM—not to optimize YOUR ownership experience.
- I consider but often deviate from official OEM recommendations not because I know better, but because I have different goals and limitations than they do. Different constraints, different goals, different approaches.
- It’s often worth considering a 40-grade just to eliminate the limitations of ILSAC and Energy Conserving designations. The formulation limits aren’t worth the tiny MPG improvement. 40-grades don’t have a maximum phosphorus value in API SP, for example, allowing higher ZDDP levels if they work for the formula.
- As a bare minimum, go one viscosity grade thicker than the OEM recommendation. Two grades are warranted in engines known to dilute the oil with fuel.
- Finally: cleanliness >>> wear protection. Engines today overwhelmingly die from deposit accumulation, not wear. Most wear-out failure modes now are driven by deposit accumulation (bore polishing, ring sticking).
The decision tree is shown at the bottom.
A couple of elaborations:
- I assume a Euro engine is going to be quite dirty inside and needs short runs of Valvoline Restore and Protect before regular Euro oils are back on the table. The antiwear and EP in Valvoline Restore and Protect is sufficiently protective, IMO, for the short <5k runs needed for the cleaning regimen. I’m guessing some Europhile may disagree with me on this point, so I defer to them. @edyvw or @TiGeo may have thoughts here and insights that correct misapprehensions on my part. (I don’t know Euro cars or requirements that well).
- Valvoline Restore and Protect is the default, and you only get to indulge other oil choices once the engine is confirmed clean and/or you have a bona fide special case that preempts the use of Valvoline Restore and Protect. For example, say you have elevated temperatures from track usage. Valvoline Restore and Protect is probably a poor choice because it tops out at 5W-30 and might collapse at temps of 280°F or higher.
- Arctic cold conditions are one of the few cases where I’d recommend the 0W-20 indefinitely, especially the excellent ESP X2 20-grades. SUPERB cold flow. The reason the HPL option here is a 30-grade is because you get superb cold flow while gaining more dilution tolerance (there’s a LOT of cold idling in harsh winters, and fuel dilution occurs even in engines not known for it. Water can be a problem too).
- The Premium Plus PCMO makes an appearance as the premium hybrid recommendation too because of the heinous start/stop requiring both very good cold flow while having great film retention when warm (30-grade).
- Dilution is a killer of both viscosity and OCI. If you want to keep a normal OCI, you need a bump in viscosity margin and some stout add pack (TBN, detergency, antioxidant). This can disqualify Valvoline Restore and Protect based on the max of 5W-30. It did for me.
This is not super scientific and it’s sort of shoot-from-the-hip. Mostly it’s just 1) start with Valvoline Restore and Protect to ensure clean, then 2) move to whatever oil can keep it clean while better meeting your needs.
I always appreciate your posts here my man. Just for reference though, my HPL primary oil for my Limited had 434ppm of moly when sampled at 7200mi. That’s a fluid specifically made for a clutch environment. I think there is more to clutch slippage in an oil formula than moly based on my experience of 1.Double check your moly there. Its ~625ppm. Hectic for a wet clutch
He’d be called SecWar nowadays, but I digressMan, I was in a meeting today for 3 hours with various tables, charts, or, as Bob Gates, ex SecDef, would call, "Death by PowerPoint."
Let me recover, I will get to it![]()
I buy a SuperTech SAE30 that’s SP …Only if it's full synthetic (possibly GTL/PAO), yes.
Almost all of the SAE 30 and 40 grades out there are conventional non-detergent oils because are made for farm equipment, lawnmowers, generators, etc. You don't want those in your car engine.
Actually, I've never seen any full synthetic SAE 30 or 40 grade anywhere, except the HPL one.
I hear that. Available time and energy get less and less every year. I've drifted away from religious service schedules and do it when the weather is nicer/bareable. Maybe it's 5 months 4k or 6 months and 8k... I'm done laying on a frozen concrete floor or the extreme opposite. So, I'm with you, all my stuff is all season.I don’t change oil just because the seasons changed. An oil I can’t use year round is not viable for me.
This is brilliant. Should be pinned here and then hang it in the Louvre.Before I get to my logic tree, some anchor points that underpin my thinking:
Lost a fantastic 5 year ME to PowerPoint - he was so good with them that Stevie Wonder could see the right decision …Man, I was in a meeting today for 3 hours with various tables, charts, or, as Bob Gates, ex SecDef, would call, "Death by PowerPoint."
I think I was thinking 502/00/505.00 type applications. Honestly this tree is such an absurd oversimplification I should haven't even tried to give it as much resolution as I did. I frankly should have boiled it down to:One question though. Is the bubble with the Euro spec, is that saying that you need a Euro spec but don't have a GPF/DF? Because if you did, you'd need an oil like a VW 504 oil. If you have a diesel, I think you need an ACEA C3 oil.
This is another glaring weakness in the tree because I couldn't really think of any non-HPL oil I was willing to take to "extended drain." I can't think of any oil marketed for up to 20k miles that I'd be willing to take all the way to 20k miles. So this is yet another part of the tree that probably should have been pruned at the concept stage.I'm curious how you chose Valvoline EP as the standard for long OCIs? Given @Glenda W. 's experience with it, it is basically blacklisted for me. It can't handle a well-cared for boxer engine on short OCIs. I'd argue Mobil 1 Extended Performance or Castrol EDGE Extended Performance for OTS long OCI options. Glenda's friend went double the distance she did before their Subaru burned oil (120,000 miles on Mobil 1 Extended Performance 0W-20 before oil burning compared to Glenda's 60k).
