We're a modest group over here ... the Camry thinks it's an Avalon.Sure hope the old Camry appreciates the exceptional care you give it. It probably identifies as a Lexus LC.
I agree that cars should be maintained well throughout their lives. The idea of spending less on an older car has some logic. First, you may not have the remaining expected life to benefit from the expenditure. I recently replaced tires on a 150,000 mile vehicle and went with a cheaper brand, as I did not anticipate the benefit from a tire with a 70,000 mile guarantee... if this car is still with us at 200,000 miles, I can regret at that point. On boutique oils, consider that you might get more utility from a shorter OCI, and avoid the increased dirt and contamination of the extended OCI. I am as much of an oil nerd/enthusiast as anyone here and on daily drivers advocate the benefits of synthetic oil purchased for $23 or less, cheap but solid filters, and 5,000 mile OCI's. There is more than one way to skin a cat.To address your comment: I've never understood why an older, good-running car should get lesser quality care and materials than a newer, more expensive vehicle. One might argue that if one wants to keep it running well and for a long time, which I do with the Camry, attention to maintenance and materials might be a prime concern.
Wouldn’t diluted PCMO have less cleaning ability?After that, because I have an extra quart of HPL PCMO 5w30, I thought I'd add that to four quarts of M1, using it like a stronger cleaner. I'd run that with about the same interval as described above. The thought is that it would afford slightly stronger cleaning than the EC, but with the small amount of HPL still be gentle.
I happened to have 3 gallons of HPL PCMO for the Prius - but it made oil consumption worse. I’m running it in another Toyota engine that doesn’t have known oil consumption issues and maybe a little longer than 5K.The Toyota will out last both of us using Supertech syn oil Shel,,,
Any idea why it would consume HPL at a higher rate?I happened to have 3 gallons of HPL PCMO for the Prius - but it made oil consumption worse. I’m running it in another Toyota engine that doesn’t have known oil consumption issues and maybe a little longer than 5K.
If this 3UZ-FE V8 isn’t drinking it, I might switch over a 2GR-FXS V6 to it, but this time in the no VII variant.
This is the route I took. Drained the Kirkland and AMSOIL Signature Series, filled with HPL and ran it. Monitored oil filters and that’s about it.just pour the oil in the engine. it's not a magic cleaner. it's just a higher quality oil. i switched to 100% HPL with no problems. didn't expect any either.
I'll follow the recommendation of the guy who designed and made the oil, with whom I have personal acquaintance, and who knows my car.This is the route I took. Drained the Kirkland and AMSOIL Signature Series, filled with HPL and ran it. Monitored oil filters and that’s about it.
For sure, if your engine is that gummed it makes perfect sense.I'll follow the recommendation of the guy who designed and made the oil, with whom I have personal acquaintance, and who knows my car.
I don't know what the inside of my engine is like. There are no indications that it's "gummed." However, it has close to 100,000 miles on it and when I purchased the car a few years ago there was no maintenance history. I'm not inclined to open it up to look inside, so following Dave's suggestion to start with the more gentle cleaning of the EC30 seems like a reasonable and safe way to proceed.For sure, if your engine is that gummed it makes perfect sense.
That I don’t know. As soon as I went back to OTC oils, that consumption went back to a reasonable rate.Any idea why it would consume HPL at a higher rate?
Mine was a 4.6 3-valve with 210k on the clock run on whatever-off-the-shelf it’s whole life, presumably it was going to be dirty, and it was. Watch the filters and motor on.I don't know what the inside of my engine is like. There are no indications that it's "gummed." However, it has close to 100,000 miles on it and when I purchased the car a few years ago there was no maintenance history. I'm not inclined to open it up to look inside, so following Dave's suggestion to start with the more gentle cleaning of the EC30 seems like a reasonable and safe way to proceed.
I wouldn’t bother with the blend step unless the engine is known to be very dirty. You’re going to HPL, so saving a few bucks by blending seems counterproductive.The time has finally come to start the switch to HPL. The first change will include Mobil 1 ESP 0w30 (because I had some handy and want to use it) with a quart of the HPL Engine Cleaner "cleaner." I plan to run this mixture for a few months and 2,000-2,500 miles. That seems to be about what Dave at HPL recommends.
After that, the plan is to switch completely to HPL PCMO 5w30. What do y'all think of this plan
