Different rvp
I though the gasoline has 10% ethanol by default. At least around here is like that. So, I assume where I live there is winter blend all-year-round. It's understandable - ethanol is cheaper than gasoline. When I fill up - 1 gallon of my tank is ethanol."Winter blend" gasoline typically adds 10% ethyl alcohol which gives the fuel less energy (around 3-4% less) when it combusts in the cylinder.
See other comment below ... at one time there was no ethanol in gasoline. Then they started just blending it with 10% ethanol for the winter months here ... I think that's where the term "winter blend" originated from. As summer approached they would go back to pure gasoline. The stickers on the gas pumps showed the dates when the 10% ethanol started and ended. Now they sticker just shows it always has 10% ethanol.I though the gasoline has 10% ethanol by default. At least around here is like that. So, I assume where I live there is winter blend all-year-round. It's understandable - ethanol is cheaper than gasoline. When I fill up - 1 gallon of my tank is ethanol.
Could be depending on where you live. Here they started using 10% ethanol year round decades ago (high population area) to reduce emissions all year round. You can still find a hand full of gas stations that have one pump with non-ethanol gasoline, and of course it costs even more.I thought 10% ethanol was the normal limit and blenders get a waiver to go to 15% in winter months?
It's just one man's insatiable curiosity asking a lot of questions that start with: "Hmm, I wonder.."I wish you'd stop posting about all this, it's got me questioning my choice of oil![]()
Sorry, the second "a" in ABA testing is unlikely to occur as once I've established the HPL chemistry I'd like to keep it. If I go back to Valvoline Restore and Protect on 5k intervals, the data will come in naturally.I hope you realize that we are going to expect you to re-run Valvoline Restore and Protect 5w30 at some point to validate / compare your previous run. Wake me up in 5 years when all the data has been charted? Please?!?![]()
did and done. Pressure are no higher than the Valvoline Restore and Protect run last year this time on the SAME rubber. And there's no way that lower pressure is lower rolling resistance.Check your tire pressures.
If you're getting better fuel mileage with all other factors that could impact fuel mileage held constant as well as possible and just changing the oil, it basically means there is an over-all less friction level between moving parts, even though theoretically the higher operating viscosity should cause more oil shearing friction/drag.For what it's worth, my tank MPG is now up to 32 (200 miles in) and the OCI mpg at just under 800 miles is now up to 29.9. The MPG enhancement of the SAE 40 appears to be a real thing. I can't explain it. It's the same fuel bought from the same stations, driven by the same driver on the route in the same usage.
Mid 600s, just like the 15w variant.If you're getting better fuel mileage with all factors held constant as well as possible, and just changing the oil it basically means there is an over-all less friction level between moving parts, even though theoretically the higher operating viscosity should cause more oil shearing friction/drag. But if there is less friction on all the parts that are in the boundary and mixed lubrication regimes that could out weight the increase in oil shear drag. What's the Moly level of the straight 40 grade HPL?
How's the HTHS viscosity compare between the 15W-40 and straight 40? How about the KV100 and specific gravity?Mid 600s, just like the 15w variant.
Agreed. That’s mostly what makes the difference kind of baffling. The two 40 grades (15w and monograde) have nearly identical HTHS and KV100. So on paper they should essentially have identical pumping losses.How's the HTHS viscosity compare between the 15W-40 and straight 40? How about the KV100 and specific gravity?
Comparing those specs could show that even if t they both have close to the same HTHS viscosity (measured specifically at 150C and 1 Million/sec shear rate), it could be that at shear rates below 1 Million/sec and at normal engine operating temps well below 150C in normal driving conditions the 15W-40 with VIIs may have more dynamic viscosity than the straight 40 grade with no VIIs. That might result in more overall shear drag with the 15W-40 than the straight 40 which could impact fuel mileage.
It basically comes down to If all other factors that could impact fuel mileage are being held constant and only the oil used was changed, and the straight 40 is showing better fuel mileage, then it has to come down to a difference in the overall engine friction level resulting from the oil.
Not sure exactly what your "pumping losses" comment is referring to ... the oil pump power required for each oil? If so, that's got to be minuscule between those two oils at operating temps. What's your term "increased traction" referring to? ... higher friction on moving parts, higher oil shear losses? More oil shearing loss would also contribute to higher engine friction due to oil shear vs the friction caused by parts actually rubbing together in boundary and mixed lubrication regimes. Just trying to understand these used terms which I haven't really seen used before.Agreed. That’s mostly what makes the difference kind of baffling. The two 40 grades (15w and monograde) have nearly identical HTHS and KV100. So on paper they should essentially have identical pumping losses. But my data is suggesting they do not, and that even the modest VII content of the 15w is enough to increase traction and reduce pumpability slightly. Enough to move an OCI mpg average from 29.0 to 30 (and climbing) so far.
Quite possible since you haven't a lot of data to compare quite yet. A test like this would probably be best if both oils were ran for 6 months each, say one run from Oct thru Mar (the "winter run") and another run from Apr thru Sep (the "summer" run). Trying to gather a lot of data might take some time over testing along those lines.But I’m thinking it’s more likely that the 15w and monograde are in fact quite similar, and the “mere” 28.8 OCI average of the 15w has everything to do with running all of winter and having all those cold starts in there.
Yeah, I'd expect the difference to be more than 0.2 mpg.I mean think about it this way: Would you expect to the difference between a 5w-30 run in predominantly warmer weather and a 15w-40 that went the entire winter to amount to a mere 0.2mpg? I sure wouldn’t. I’d expect it to be more like 2mpg or more in favor of the thinner oil.
More time and data collection might shed more light.Also, keep in mind that the monograde has a winter gauntlet yet to test it. There’s a good chance (a near certainty, actually) that the MPG of the monograde falls off a cliff once some truly cold weather comes in.
However, I’ve had several starts near freezing and already within a tank OCI haven’t noted major losses. So who knows, maybe the monograde really comes through the winter with flying colors like the 15w did.
