It’s based on the old 318 LA engine, but AFAIK there was never a non-magnum version, so the 3.9 always had the Magnum still changes (stud mounted rockers instead of shaft, oil through pushrods, vertical intake bolts, etc). Still the same 59 degree lifter bore block that goes all the way back to the 1964 273 introduced for the Barracuda. That was the first “LA” engine (i.e. Lightweight “a” engine). The other old polyhead 318 A engine didn’t become the LA variant until 1967.
The 3.31” stroke was the LA stroke length for all engines until the 360 came along in the 1970s. The stroked it to 3.58” and bored it to 4” even (a decrease from the 4.04” of the 340). Because they used cast crankshafts, the 360s all had external balancing— typically an offset weighted crank damper and/or (get this) specially weighted torque converters.
Yes, they balanced the engine in the torque converters. SMH.
Give me a 318 over a 360 any day.
