2002 Dodge Dakota 3.9 v-6 HPL CK 4 5w-30 UOA 3k mi
In the shop
Here’s the UOA of HPL CK4 HDEO 5w30 that was in use for 3,000 miles
Oil is still in service also; I’m happy with this report as welll.
Oil Type: :ROFLMAO:
Looks good & It seems Si might be higher in this oil new as I saw another one with 20 PPM too. Sodium is noticeable as well. It seems Na was elevated in another sample posted here. Overall, you should be able to run it longer like you want to. Do you know when you'll resample? Did you add any oil during this 3k?
https://bobistheoilguy.com/forums/threads/hpl-5w-30-ck-4-10-000-miles-2002-gmc-2500-hd-6-0.388701/
Lot's of Moly! Maybe I'm not understanding, but isn't that really high for Calcium and Zinc? I know this engine is not GDI, but my engines are.
Thanks Adam for sharing this with us!
Not for CK-4 oil. Probably wouldn't want to use this in your engines.
Oil Type: :ROFLMAO:
I added oil too refill Toyota filter before installing
Is this a first run of HPL or second run?.
To clarify; this is first run of HPL CK4 HDEO 5w30. Oil still in service.
Oils used before were unknown, FRAM 15w40 conventional and my first oil after acquiring truck was Rotella T5 10w30
Oil Type: :ROFLMAO:
Justin: it’s not bad ass HPL oil. Folks at lab must not have read my slip that comes with sample kit. I wrote HPL CK4 5w30 HDEO
Thinking of going to 10k on this oil and resembling too. May run the Toyota filter on for 3k then toss on a NAPA Platinum 41348 for last 4k
I should do one of these on my 00 3.9L.. If I remember I will next time. Don't know how to interpret UOA's but I bet it's numbers would be sky high compared to these. It has a knock that can't figure out but excellent oil pressure.
Mine has great oil psi just no knock
