HPL EC treatment started. 2007 Camry 2AZ-FE 153k consumption.
If you want the carbon off those pistons, do a water de-carboning.
Fill a spray bottle with water, take the air cleaner hose off the TB, and spray shots of water into it as you rev it by hand.
Old technician trick!!! We use to do this all the time. Cleans the top end to near spotless.
Thought I would mention a problem with oil consumption on a Chevrolet equinox 2.4 that I was mostly able to resolve recently. The 2010–2017 GM Ecotec 2.4 has a serious problem with oil consumption. In some cases worse than what you’re experiencing. Many claim it’s the piston rings GM used. They don’t have enough tension so they allow oil past them and need to be replaced with high tension piston rings. Oil consumption diminishes. I have found that’s a Band-Aid for the real problem. The real problem is a blocked PCV orifice located inside the intake manifold. Relieve the blowby pressure, let the engine breath, the oil consumption is dramatically reduced. I modded the PCV system, bypassing the orifice adding a conventional PCV valve. I’m mentioning it as something to consider for your problem. Maybe it’s not functioning correctly.
That certainly sounds like a plausible cause, but I have never come across that in any discussion of the 2AZ-FE consumption issues. It is always 100% the return holes being too small and the rings being low tension.
The PCV valve was replaced last year, so it should still be good. I only have 100 miles on her right now since the soak because of the radiator leak. That is being replaced tomorrow after I vote. In the meantime, I know that the soak did at least something because the early morning start struggle is completely gone. She starts up better than she has in a looooooong time.
I'm glad someone is enjoying this, haha. I have two more OCIs worth of data sets on the consumption that include BG EPR to share, but figured I would do that when I finish the soak. In the meantime, the same car has been through the ringer. At some point the battery light came on, and after changing out the battery and then the alternator, the light still comes on 10 seconds after starting, so it must be some corrosion or something somewhere along the circuit because after hours poking and prodding everything I could think of with a multimeter the actual charging system seems fine. Then, a month ago this happened:
View attachment 246437View attachment 246438View attachment 246439
Initially insurance declared it a total loss, but after it got towed to the appraiser they said she was repairable because she was still drivable. That is about 1/3 of the branch that actually fell on it, and in addition to destroying the windshield it banged up the hood pretty good. So that was a fun claim. BUT THEN when they rolled it back off of the tow truck at my house she had this:
View attachment 246454View attachment 246455
At some point the geniuses that my insurance contracted with backed a rolloff or tow truck or something into it. So that was fun. And I'm pretty sure that branch cracked the radiator because she is leaking just a bit of coolant when the system is pressurized, so that is a future project. But the wife insisted we not have two older cars that were beat to hell so I finally caved and got a used Pilot. Now the Camry is my daily beater to and from work in the city so it has also become my experiment car.
Thanks for the updates. Subscribed
Quick Update:
November 12, 2024. 161,034 miles. 195.1 miles into OCI4.
I don't want to get my hopes up, but things are looking fantastic. 200 miles since the soak and if the oil level has dropped at all, it has just barely done so. I couldn't get a good picture of the dipstick with the morning light, but I marked where the level is. I underfilled the oil slightly when I did the change, so it may not have moved at all.
350 will be the next check, as there it would have been down a quart prior to the soak.
If that is where you filled it to originally that is about 3/4 qt low to start. My OCD would make my eye twitch and toss at night thinking about it. I know they say "between the dots is fine" but for me that's almost 25% of my capacity.
As long as you know where and can monitor it. Between 6 vehicles for me I go full top dot/mark. If it drops any, I'm burning or leaking. If it gains any probably fuel dilution.
I am typically the same way, but the oil was so clean after the soak that I could barely tell where it was on the dipstick. I didn't want to add any after I started driving and it actually became dark enough to read. It might be slightly down from when I initially filled it, but not by much at all if it is.
I am also using an oversized filter, which probably caused me to underfill when looking at the 5-quart jug.
Update #2
November 21, 2024. 161,148 miles. 309.0 miles into OCI4.
Looking good. Looking real good. The level may have decreased a tad (it is difficult to say with the underfill), but the consumption is down big time. By this point before the soak the level would have been approaching the bottom dot. I am just going to keep checking at 400 miles, 500 miles, etc. to get an eventual rate of consumption. And while I know the underlying problem isn't fixed, I don't really care. I am chalking this one up as a win.
I, personally, if I had one of these I-4 low tension oil burners, would be tempted to do something of an "in-frame" re-ring job. Take the cylinder head and the oil pan off, push the pistons out of the top of the bore, dingle ball hone cylinders with 400 grit, and put in some file fit rings with no more than 15 thousandths of clearance on the top and second ring as measured with a feeler gauge.
Replace rod bearings with stock since they're already open, and timing components, button up and run it.
I don't frequent Toyota/Honda forums where these problems are well known, but has this ever been tried? No separating the engine from the transmission, no engine hoist or stand, etc. Maybe could help?
I did it on my $125 ‘90 Civic wagon years ago-.001 undersize rod bearings, standard size rings (crosshatch visible, honed, oil control rings jammed with carbon) had the oil pan hot tanked (it was really nasty), had a machinist friend resurface the head & replace a couple exhaust valves. Wasn’t hard at all.
Update #4
December 9, 2024. 161,374 miles. 535.7 miles into OCI4.
It doesn't look like any movement to me.
Having now driven her for 500+ miles I can conclusively say that the engine both feels smoother and sounds quieter, and she definitely has more hitch in her giddyup. It might be confirmation bias, but I feel like she has not accelerated this well since when I bought her at 60k miles.
And the motor is nice clean since the oil is still nice and clean. I've seen many vehicles at a 1/4 of that mileage that the oil turns dark from junk the moment it is circulated after a change.
I should have taken a picture when I changed the valve cover gasket. I'm no expert but it certainly looked clean to me compared to what I have seen online. I did run three quarts of HPL Engine Cleaner and two cans of BG EPR through her before doing the B12 soak, so all things combined I would be disappointed if she wasn't sparkling inside.
8 pages. Can we get a TLDR here as of today? I just don't see HPL Engine Cleaner doing a whole lot, it's not intended to be a flush product, just a preparatory product to switch to their oil which on it's own has been shown/can do some cleaning.
  • Like
Reactions: wlk
TL;DR: The HPL Engine Cleaner experiment ended a while ago and could not resolve my oil burning issue, which was too advanced. Since then I have run BG EPR through her and then soaked the pistons with Berryman's B12. Now I am just updating with the ongoing monitoring of results from the B12 soak, which so far appears to have been pretty effective.
Appreciate the response. Yes, EC is just not for this purpose so no surprises there - while I understand/"believe" that products like this, HPL's regular oils, the new Valvoline Restore and Protect can have some impact on deposits (and if used from day 1 should prevent many in the first place) a more targeted treatment like the BG product and the Berryman's is where you need to be at the point where you have significant loss. Good to see it worked...many report the same results.
I'll give the HPL plug for 2 OCI's with EC30 over 8737 miles and then 1 quart of HPL 5w30 PCMO added to Pennzoil Platinum Euro L for about 5k and also on latest OCI with about 3k on it so far in daughters CRV. So about 18 months and just shy of 17k. I know full HPL or maybe Valvoline Restore and Protect might get more, faster. I'm OK with this since it also gets a lot of short trips. It doesn't burn any so not worried. It had BG EPR done a year before I started the EC30.
I can say that I have so much here at BITOG and would have no issues doing a Piston soak if I was having real issues. Maybe in my Accord some day.
Low flow area Baffle plate on '08 CRV now with 240k on it.
That HPL is working
