I read your post right, and said why there was fog created in the pressurized bottle trick. Yes, fog will appear if moist air is compressed, then suddenly decompressed. But fog can also form in moist air any time the air pressure gets low enough below the normal atmospheric pressure - the air doesn't necessarily have to be compressed first.You obviously did not read what I said. YOU FIRST PRESSURIZE IT THEN RELEASE THE PRESSURE THEN YOU HAVE THE FOG AS THE AIR PRESSURE FALLS OFF. When dense it packs the water when released it turns to gas or fog.
I could demonstrate a wing creating lift with no airflow what so ever over the top of the wing. Matter of fact I could also add some weight on top that wing with stagnate air covering the whole top of the wing. Some day when I have lots of spare time I'll build the demonstration wind tunnel to do that.
Bernoulli ? Not needed to fly. For venturi's yes.
Why do you think vapor only forms on the top side of wings, and why do wings bend upward while the plane is in the air - see attached video. When the moist air above the wing area simply lowers below the atmospheric pressure (without being compressed first), then water vapor in the air will turn to fog.
