They knew there was a significant discrepancy between the FO versus CA indicated airspeed and should have rejected the take off.
Pilots cross check their airspeed on every take off ( 100 knots usually ) and when they are not indicating the same speed, reject.
But that reject needs to happen at the crosscheck, not at V1 after fumbling over the decision. That is the exact scenario that happened on a 767 once. At the 100 knot call, the captain’s airspeed (round dial) was in error. Captain’s speed tape on the Primary Flight Display (PFD) was good. Standby was good. FO round dial and PFD were good. So, 4 of 5 good.
I would have taken that flying, sorted it out airborne (may not have been able to do RVSM, for example).
But the Captain waited, rejected above V1, smoked the brakes, blew tires, and caused all sorts of heartaches.
So, yes, reject at low speed. Up to 100. In the high speed regime? I would take it flying. Sort it airborne. High speed rejects carry an entirely new set of risks.
The fumbling over the decision is unacceptable.
One of the things I emphasize in training, checking, and of course, flying, is a precise brief. The brief itself is a mental rehearsal. I loathe pilots who say things like “Reject is standard”. That is a failure to prepare, a failure to harmonize understanding across the crew. That kind of brief gets an unsat from me.
A rejected takeoff brief should start with something like this, “If you see something below 100 knots, call it out, I will either say continue or reject. I will reject below 100 for any critical system failure, be it hydraulic, electric, fuel, engine, or flight control. Above 100, I will only reject for engine failure, any fire, windshear, or the airplane is unable or unsafe to fly*”. “If I announce reject, I will go throttle idle, disconnect, speed brakes first, then reverse, above 85 knots, the autobrakes should engage. Back me up on speedbrake extension and auto brake engagement. Tell tower we are rejecting, and the runway we are on. If we reject above 100 knots, have them roll crash fire rescue. As we bring the airplane to a stop, tell the people to remain seated, then, regardless of the reason for the reject, we will do the rejected takeoff QRC from the card.”
Clear. Concise. Detailed expectations. Mental rehearsal as I point to the throttles, speedbrake, autobrakes, and QRC location. We, as a crew, now know exactly how we will execute this, and why.
Back to airspeed. Loss of one of 5 isn’t a big deal.
But BirgenAir 301 took it flying. Taking it flying is not a bad decision, but it is only a good decision if the crew can handle the emergency correctly, and they, frankly, did not. This is an accident involving a 757, so, I talk about it with crews. The airplane had sat for three weeks and did not have pitot covers for part of that time. Mud daubers built a nest. The Captain’s airspeed became an altimeter (which is what happens when a pitot tube is blocked), but the FO’s indicator was OK.
They failed to identify the accurate information. Lots of clues exist, IRS ground speed, standby instruments, trim, handling. They focused on systems (resetting breakers) instead of the critical task of flying the airplane manually. They kept climbing, which makes the airspeed discrepancy worse. They stalled it, and crashed.
In fairness to them, we now spend much more time training this scenario. It is required training. Crews are quick to recognize and analyze the situation. Training works.
A sea story from “back in the day”. I was flying through build ups, at night, off the carrier. Absolutely black night. No horizon. We flew though one particularly heavy rain shower while trying to find another airplane on radar - The airplane was about 350 knots, about 2 degrees nose up, wings level, and I had the throttles about halfway up.
Our airspeed went to zero while we were in the rain. I asked my RIO, “Hey, Ferris, what do you show for airspeed?” He said, “zero”. I replied, “That can’t be right. We were flying a second ago, and I haven’t changed anything.” He replied, “Our INS ground speed is 400”. “So, something happened to our airspeed indicators, then.” I said.
We didn’t touch anything. Kept wings level, 2 degrees, same power. A minute or two later, as we flew into clear air, the airspeed started working again. We were still about 300-350 knots.
Point is: you have to analyze. You have to determine what is real, what is accurate, and what is not. You absolutely must avoid panic. You absolutely must control the flight path of the airplane first, before starting to troubleshoot. Just like Ferris and I did that night.
*Unsafe to fly encompasses things like an airplane crossing the runway, flight control malfunction, failure to accelerate, loss of directional control, as examples, again, it need to be thought about and briefed at the gate, not at 100 knots.
