- Joined
- Sep 2, 2016
- Messages
- 984
2004 Volvo V70 w/ 100k miles
Getting an intermittent fault code for "pump motor supply voltage faulty" (BCM-0070). It goes away after clearing it but eventually returns. Did some research and it seems that the most common cause is worn brushes inside the motor. Apparently they wear down from the self-test procedure after every start, which tracks considering the vehicle's age. The motor is simple to remove without touching any brake lines or hydraulics. Unfortunately there are no pick and pulls around me and local wreckers want $400+ for the motor, so I figured I would attempt to replace the brushes myself.
Problem is, how on earth do I pull this bearing with no clearance? I've seen posts where users were unable to remove the bearing with normal pullers, as well as other posts were users replaced the brushes with no mention of the bearing at all, suggesting it's no big deal. Is it possible to replace the brushes without removing the bearing?
And sample photos of said brushes. They appear to be 5x5x12mm brushes but I'm not sure of the material - copper carbon was recommended?
This car is a daily driver so I am trying to research as much as I can before I do anything to minimize downtime.
