I know that both contain esters, gtl, pao. According to Mobil’s product sheet, the 0w-20 flavor has slightly more phosphorus and zinc. Are the other additives pretty similar? I know that 0w30 has a much higher HTHS.
The correct answer is that the 0w-20 is green. Haha. I’ve used both in our van. Has the 0w30 in it now. Don’t notice a difference honestly. I know they target different specs but they seem similar: both are API SL and meet SP engine test requirements.Didn't know they had GTL in the base. I do know that VW 508.00 is a very tough approval to meet, more so than VW 504.00 IIRC. And the difference between the two is that I will use the 0W-30, but will not the 0W-20.
Both are good oils but one is 50% thicker which usually is the determining factor in which one to use.I know that both contain esters, gtl, pao. According to Mobil’s product sheet, the 0w-20 flavor has slightly more phosphorus and zinc. Are the other additives pretty similar? I know that 0w30 has a much higher HTHS.
That’s me tooScrew that! I am one of those obnoxious hyper-milers that tries to squeeze every last penny out of my fuel economy. Gimme that 0w20 ESP with the 7.9cSt and I'll show you how to milk the MPG all the way to the bank![]()
Me three but I gave up Mobil 1 in the early 80sThat’s me tooI have been running ESP 0w-20 in my Civic now for just over 2000 km and I know it’s hard to see very minor changes in fuel consumption but it’s nice knowing that it might just be giving me 0.1 MPG better than my previous oils, which were all ever so slightly thicker (by maybe 0.5 cst at 100c)
You appear to have misinterpreted me. I wasn't saying they should use the 0w30. I was saying that the thickness difference is so great. It usually determines what the person wants to run, whether the 0w20 or 0w30.Screw that! I am one of those obnoxious hyper-milers that tries to squeeze every last penny out of my fuel economy. Gimme that 0w20 ESP with the 7.9cSt and I'll show you how to milk the MPG all the way to the bank![]()
No not at all. Your engine generally shows significantly less wear on a 30 grade oil. Check out some of the used oil analysis on your engine.Good question @Klutch9 I was thinking of going to switch from the ESP 0W-20 to 0w30 for my baby Duramax. I wonder if that would be a problem.
which spec determines thicker?You appear to have misinterpreted me. I wasn't saying they should use the 0w30. I was saying that the thickness difference is so great. It usually determines what the person wants to run, whether the 0w20 or 0w30.
Really? Where the heck is Goldilocks when you need her?0W-30 is too thick and 0W-20 too thin, only a measly 7.9
Based upon the approvals it has, ESP 0w30 has to have a minimum HTHS number of 3.5I’m assuming HTHS for the esp 0w20 would be greater than or equal to 2.6, even though the KV seems pretty low.
That got me thinking, is the esp 0w30 3.0 Hths or 3.5? Can’t really find a reliable source for the Hths of the esp 0w30
Yes. It will explode. I would drive it with a bulletproof helmet just in case the rod bearing finds its way through the dashboard.Good question @Klutch9 I was thinking of going to switch from the ESP 0W-20 to 0w30 for my baby Duramax. I wonder if that would be a problem.
0W20 2.76cP as far as I remember.I’m assuming HTHS for the esp 0w20 would be greater than or equal to 2.6, even though the KV seems pretty low.
Which illustrates the importance of HTHS.It's an interesting dynamic because the 0W-20 is nearly a 0W-16 while the 0w30 is just a hair below a 0w-40
Throw in a dash of fuel dilution and it can be a 0w12, 0w16 and 0w20 simultaneouslyI'm getting rid of this car after the 8-year 120,000 mile warranty is up so I don't care about how long the engine lasts
