T Turk Joined Feb 3, 2006 Messages 9,103 Location MN Apr 28, 2008 #1 Howdy, On my '03 GMC Sierra with 125,000 miles that I want to keep a very long time, how often do I "truly" need to grease the Front End...? I do all my own oil changes, so I do not grease the Front End as often. Thanks...
Johnny Joined May 27, 2002 Messages 14,013 Location Retired | Wausau, WI Apr 28, 2008 #2 How often do you do oil changes. IMHO it should be greased at least every six months, depending on how your truck is used. If you do a lot of off road travel, through water, or carry heavy loads every day, then grease it more often. Grease is cheap.
C -Clayton- Joined Oct 27, 2005 Messages 1,261 Location KY Apr 28, 2008 #3 I try to grease at least 3-4 times per year, usually 3.
S sunfire Joined Apr 8, 2008 Messages 1,574 Location Ca, US Apr 28, 2008 #4 How do you grease your car? I have a Corolla thats never been greased, does it need greasing?
GMBoy Joined Nov 22, 2004 Messages 10,110 Location Texas Apr 28, 2008 #5 I grease mine every other oil change. My OCI is 5-6k so I grease about every 10-12k.
T Turk Thread starter Joined Feb 3, 2006 Messages 9,103 Location MN Apr 28, 2008 #6 I have a 5-7k OCI with Syn. I grease it about every 15k. It has all of the original Front End parts, tires wear well, should get ~80k out of them, no pulling to either side and no shaking either...
G Gregory Joined Aug 24, 2004 Messages 412 Location Tn Apr 29, 2008 #7 Anything that has a zerk fitting gets grease every 5k.
