Primitive IRS Axle Spline Grease
New England, USA
Looking for thoughts on lubrication for the rear halfshafts on my TR6. The half shafts have splines, but there are no grease nipples, so this is a lube and forget until the next time you remove them situation and there is no reason to remove them (other than service) besides replacing the u joints or the wheel bearings, neither of which fail very often. That said, I do remove them and re-lube every 10 years or so.
The original spec'd grease (from 1974) is NLA and I was using Honda Moly 60 paste which is also NLA. I am out of the Honda product and looking for thoughts. These splines do get a workout and when they bind it gets exciting, they bind that side of the suspension. I haven't happen since my first TR6 in '82 and want to keep it that way :)
Thoughts and experience??
eyJ3aWR0aCI6ODAwLCJoZWlnaHQiOjYwMCwiZml0IjoiY29udGFpbiIsIndhdGVybWFya2VkIjp0cnVlLCJrZXkiOiJhc3NldHMvaW1hZ2VzLzEwNDYzMDE0L2xhcmdlLzk5NzM3N2Y5NWFkNmIzODBkMjFkYzJiYjNmMWM1YzRmLmpwZyIsInZlcnNpb24iOjJ9.jpg
