You can't buy a vehicle outside CA and register it there until 7500 miles? That's insane. I knew it was a dictatorship but wow.Not an option - won’t be able to register it until the vehicle has 7500 miles.
https://www.dmv.ca.gov/portal/handb...oncertified-direct-import-vehicle-exemptions/You can't buy a vehicle outside CA and register it there until 7500 miles? That's insane. I knew it was a dictatorship but wow.
That's probably not true even for CA. Will brace in case I am wrong.Yam unfortunately my state does not normally allow citizens to buy new a car out of state
Having to meet federal emissions rules does not seem like that onerous an issue.https://www.dmv.ca.gov/portal/handb...oncertified-direct-import-vehicle-exemptions/
There are exceptions but…
Well…brace…That's probably not true even for CA. Will brace in case I am wrong.
Then people in California should stop complaining about the above MSRP mark ups. Their government has created them. The local dealers have an oligopoly, can't blame them for using it.Well…brace…
Read the link. You cannot buy a new car outside CA and register it unless you meet certain conditions, like military service or your vehicle was damaged while out of state, or their was a divorce, or other property settlement.
Once it hits 7,500 miles, then it’s a used car and can be registered if it meets Federal emissions standards. But until it gets to 7,500, it cannot be registered in California.
Simply: you cannot buy a new car outside California and register it in California.
Pass the company website if you're having trouble finding what you want at the price that you want... takes minutes on these sites, maybe worth it to put out there. Every dealer has slow days... and they know people shopping there are not going to settle for the markups you are seeing. If you like something, why would a $60 fee get in your way to join?Kinda thinking of getting out of my jeep and into a little truck. The jeep is great for playing but not very useful in town. Can't carry anything in it etc.
Plus I don't think we need two 4 wheel drive SUVs. I do need a 4x4 regardless.
Looking on Toyota's site I "built" my Tacoma and it came to $31k. But the local dealer wants $44k for it. They have a $7500 markup above window sticker and they tack on all kinds of stuff I don't want like window etching and other wallet flushes and they won't drop the price .
Is this normal now? No haggling?
How does the "Steve Jobs loophole" factor in ?Not an option - won’t be able to register it until the vehicle has 7500 miles.
I think you are wrong on this, the car must meet CA emissions standards, that is all as far as I can tell.Yam unfortunately my state does not normally allow citizens to buy new a car out of state
Yeah, that's the marketing speal, my subaru has it and its an interesting trick that works pretty well on a smooth icy road, but I rather have a low range if I was going down steep stuff off road semi regularly...I am in no way inferring hill descent control is required - but to answer your question - yes its much better than just throwing it in 4 lo. It uses the ABS individually on each wheel - to maximize traction per wheel - in real time in milliseconds. 4 lo and brakes simply mean all brakes get the same force - so there is no way it can compete.
What your saying is the equivalent to saying old manual brakes are better than ABS. I think most people have finally realized there not.
Now if you need hill decent control - another matter. Both my 4x4's have it. The couple times I used it - very impressive. Not many hills here though.
I also think that the vehicle can be from the Northeast which uses CA standards.I think you are wrong on this, the car must meet CA emissions standards, that is all as far as I can tell.
I feel your pain, but this has been the norm for 3+ years now with dealer purchases. There's got to be a 200 threads on this on BITOG alone.
The problem is worse with Toyota and more terrible yet with supply/demand and cult like followed vehicles like a Tacoma.
Reading your threads over the years, would you really be happy with a new Tacoma at the price they command?
Lots of unhappy owners have traded them for (gasp!!) 2022+ Nissan Frontiers over at a Frontier board I follow.
My hill descent control only works in 4HI or 4LO and only under 15mph - otherwise you just have the normal ABS/traction control. Also, I can put it in D, it won't matter, it holds low gear unless I floor it. So, no not a marketing speel. There is even a button to press to disable hill descent control if I choose.Yeah, that's the marketing speal, my subaru has it and its an interesting trick that works pretty well on a smooth icy road, but I rather have a low range if I was going down steep stuff off road semi regularly...
If your hill descent control is usable in 2wd or 4 hi, try it alone going down hill rough hill leaving the transmission in D, and you will see the limitations of brake control on each wheel individually, as ABS can't replicate the steady constant under rotation of the tires locked to the drivetrain speed regardless of how much grip each tire has.
Then try 4 lo and locked in low gear with no HDC and just drag the brakes a bit, to help the open front diff distribute engine braking evenly, and add some gas as needed to maintain speed. Should be much smoother with less locking and unlocking wheels.
