Well I do something a little different. I dont prefill my filters, but I pull the coil wire off while I turn the motor over. After2 seconds of turning the starter the oil light goes off. Plug wire in and whammo, oil pressure.
You aren't the only onequote:
Have I mentioned I'm anal?[/QB]
This was also my observation when I pre-filled my filter, whereas it took several seconds otherwise. On a car with the filter mounted base-up, I now can't see why you wouldn't pre-fill.quote:
After I fired it up, the oil pressure came up just as fast a if I'd never replaced the filter.
Did that a few times with different SBC's. Now, this was not after an oil change, just for valve train adjustment. From engine light to visible oil flow was at least 2-4 seconds. I would think the interval would be longer after an oil change.quote:
Originally posted by toyo:
I think yall are wasting your time. HAve you ever turned an engine over with the valve cover removed? The oil sprays instantly. I am not trying to start an argument, but the oil flows very quickly.
have looked at this thread for a while....quote:
Originally posted by Darryl:
gtx510:
You run the engine with only a 1/2 quart of oil in it?
To each their own, but I won't even start my engine if its only 1 quart low, much less 3 1/2 quarts low
Just my thoughts, not an attack
Darryl
I'm with you- I fill mine 3-4 times throughout the change process so it's nice and full when I'm ready to put it on.quote:
Originally posted by labman:
I prefill mine several times. Try it next time, fill it clear full and let it set a few minutes. The oil level will drop. I take the filter out and fill it with oil before I pick up the wrench for oil plug. As I go through draining the oil and removing the old filter, I keep adding a little more oil. By the time I am ready to put the filter on, it is about 2/3 full and holding. It sets at about 4 o'clock. I can get it on without spilling much.
This topic keeps coming up, and nobody else seems to really fill their filter like I do.
The oil sprays instantly because of the ADBV in the filter. Change the filter, and the oil in the lines up to the top will drain out.quote:
