I'm running the sd76 amsoil filters on my vehicles and always pre fill them. 2 quarts of oil is a lot of oil to pump before the engine gets any oil.
Originally posted by TallPaul:
[QB] I prefill.
Anyone who leaves it drain overnight should be aware they might lose oil pump prime. Happened to me and I didn't leave it drain very long. The fix is to squirt some oil into the hole in the filter mount next to the mounting stud (if you can reach it). Backfilling this hole also will force the used oil out of that passage and the pump, into the pan and out the drain (if still uncorked).
I'm a prefiller from way back too. As far as draining overnight, I agree with TallPaul- be careful. I had an old beater 79 Horizon once back in college that lost its prime and gave me a little scare. When I started it after an extended drain time, my dummy light would not go out and engine was a little noisy, so after I checked to make sure I had put in the oil, and the new Fram 3614 had not given up already, I started it back up and gave it a good jab to the gas pedal, and all was well again. That was the 1.7L VW-derived engine-a tough little bugger with well over 200k mi. when it was retired.
Great idea. I would check how tight the filter is after the filter and engine's temps equalize. Also might wait a couple minutes for the oil to "thaw" before starting the engine.quote:
Originally posted by unDummy:
And, to make it less messy, fill and freeze the canister. Cold oil gives you more time for installing before it leaks.
I'm guessing that he is, but there are reusable oil filters available...quote:
Originally posted by Jelly:
You're joking, right?quote:
Originally posted by Gerret:
I rinse my filters out with soapy water then re-use them.
Originally posted by sjlee:
[...]there are reusable oil filters available...
http://www.vortexfilter.com/
Can you explain why the oil pump lost it prime for the extended drain?quote:
Originally posted by MSF:
On my '97 Camry 4cyl the oil filter is inserted vertically (open end down) so pre filling would make a mess. I usually crank the engine a few times (after filling and replacing the filter)to pressurize the system and then start it up. Never hear any unusual noises.
On the otherhand, My '91 Mazda Protege LX (4cyl, dohc, 16 valve) had a problem during its first oil change. I couldn't get the OEM filter removed and it sat for ~12hrs with a dry crankcase/oilpan. When I did get the filter replaced and oil refilled it made some sickening knocking/pinging/etc when it was started. I freaked and had it towed to the dealer and they checked it out. No damage was caused but the oil pump lost its prime during the extended drain. That engine continues to amaze me after 178,000 miles!
