So as it turned out, in the Generac GP700E (older version), I did drain the fuel before storage, which I usually don't do, but...I guess that since there's no side drain plug on the float bowl I must have ran it dry and still left a slight bit of fuel in the bowl. Now I starts fast but only runs on full choke. Half choke it runs but not well, here we go again, and it's not an easy carb to remove. Back to the fuel question...the machines that I'm concerned about have fuel that is at least 3 yrs. old in them. Some maybe as long as 5 or 6 yrs., that why I asked what is too old. I usually run them if I get a chance and if they run well I return them to storage. When you siphon the fuel out you usually leave the worst part at the bottom. Maybe I should do one at a time and use a water separating funnel to put it in my mowers.
