Originally Posted By: RamFan
Aren't you concerned about that much oil consumption causing a problem down the road that may leave you with a dead car that would cost more to repair then it is worth?
Not in the slightest bit concerned, no. This is because, going back to when I first researched the problem, and its likely cause (which has since been supported by a number of observations made over the past year), I researched it to death on different Corolla forums where other 8th gen owners were dealing with the same problem as mine.
There was a unanimous consensus, based on the many accounts of these cars with this same problem, routinely going to the 250k mark without any issues occurring in that span that could - in any way - be linked back to the oil consumption issue. Owners instead using decided to dump them at between the 200-250k mark, typically (though some opted to take them well beyond) because of the kinds of nickel and dime - but unrelated - repairs that tend to set in at that mileage.
So there's therefore, based on considerable research undertaken on the issue, to conclude there's the slightest hint of any likelihood of the potential related problems surfacing down the road. Early on that was one concern that motivated the research, and out of that research produced the conclusion that I was better off keeping a fundamentally sound and reliable car than trading it for a wild card used car (I don't buy new).
I love the car and have since the day I bought it and began nursing it out of its "too little" use syndrome into the well tuned machine it is. I also wound up looking at the oil consumption issue as a challenge and project within itself, which meant in turn that it never bothered me as it might others.
A year later, and over that course I've experimented with a few of the recommended remedies that sometimes work. None of them have worked, but I haven't tried them all, and I take consolation that there's been no deterioration, on the flip side. I have two more inexpensive things I plan to try aimed at curing, or reducing, the problem at the source. If those don't work I'll chalk it up as to experience gained and first hand knowledge of different products I haven't used. And by then I should have reduced my oil stash to the point that I can go the more time tested route of using a thicker, High Mileage oil.
Its also worth taking into account that I not only live in the rust belt, but what could be readily argued is the capital of it. Even though I plan on putting the bulk of my summer car work (a hassle to some, but I enjoy it) at hardening the car against corrosion, I still realize that as a year round DD, I can expect at best - even with the current factory undercoating and my best efforts (that are more elbow grease than cost) - the car will last about 3-5 years before it begins to lose the battle and I'm forced to concede it. And its rust that'll be its end, which owing to the low mileage on it when I bought it, combined with my own 20-24k km typical annual usage, it'll still be pretty low mileage at the point the cancer sets in beyond recovery.
Then I'll move up to the newest 9th gen I can afford (introduced in 2002 with the consumption corrected but mostly identical otherwise) which was outside my means when I bought this car, but will be easily attainable by then.
And that in and of itself says a lot about a car when you like everything about it so much that you want to stay with that model. My seller did exactly that too when she sold me this one to buy a brand new '10 Corolla after 10 years of inexpensive and dependable service from this one (I have the car's entire service history as proof of that).
-Spyder
