Originally Posted By: DrScientist
So to sum up what I've learned:
Filtration is secondary to flow when it comes to motor oil.
The thing is, with today's filter technology you can have BOTH excellent flow and excellent filtration efficiency.
So which one would you recommend, sir?
For an everyday street car that isn't ran hard very much, I'd consider filtration performance because even a PureOne with 99.9% @ 20 micron efficiency will still flow many times better than the engine will need. The link I posted a while back in this thread showed that a medium sized PureOne will flow 12 GPM of hot oil with a 5 PSI pressure drop. How many stock street car engines can pump 12 GPM? ... not many at all.
Originally Posted By: sayjac
Perhaps if I raced a car regularly at WOT, I might consider the question, but I don't so it's a non factor for me.
Exactly why I said what I did above.
If I was looking for a filter for a race car (ie, WOT at redline very often), then I'd use a racing filter that is specifically designed for super flow performance.
