Below is information I received from Royal Purple concerning the location of the by-pass valve in an oil filter:
It makes no difference where the by-pass valve is located. Dirty unfiltered oil is being released through either way. The by-pass is a safety measure so as to allow the engine to never starve for oil. Unfiltered oil is way better than no oil or restricted oil.
No actual advantage exists from either by-pass location over the other. When the by-pass opens to allow for appropriate cold (thicker) oil flow volume, that unfiltered oil is not significantly cleaner with the by-pass in one location or another. It’s still unfiltered oil.
Some filters have an inferior filter media, typically cellulose (paper) or a blend. Others, such as the Royal Purple, use wire screen backed 100% synthetic micro glass filter media. These filters do not release significant amounts of the captured particles into the by-pass oil flow, so it really is of no consequence.
Oil filter manufacturers may also refer to micron particle size, but often do not share the capture rate for each particle size. Without the rate of capture associated with each particle size, this information is practically of no value.
Based on ISO 4548-12 multi-pass test methods, the Royal Purple filter efficiencies are as follows:
99% at 25 microns and larger
98.7% at 20 micros and larger
80% at 10 microns an larger
In addition to very fine filtration, the Royal Purple oil filters offer very high flow volume and are appropriate for most race applications. The Royal Purple oil filters are also built to withstand a burst pressure up to 600psi.
Please refer to the following link for Royal Purple Frequently Asked Questions:
http://www.royalpurpleconsumer.com/resources/faqs/oil-filter/
Based on the above information, I have come to the conclusion that there are many other more important features to look for, other than the position of the by-pass valve, when selecting an oil filter. Of much more importance is the filtering media and overall construction quality. From my own personal research on this matter, I have noticed that all the high-end filters, those intended for use with synthetic oil and 10,000 to 15,000 miles oil change intervals, have a dome-end by-pass valve and not a thread-end valve. Can that be conclusive evidence that it does not really matter where the by-pass valve is located? I would say probably yes.
