Homelite Vac Attack model UT-08542
Carb part number 308028004
The issue is the choke does start the engine. If I block the carb throat with a rag the engine starts and runs fine.
If I pump the primer bulb 20 times and pull the start line the plug does not get wet.
The carb has a weird butterfly setup. When I look into the throat there is a half moon type shape in there that I think is the butterfly.
When I put the choke on, arm up vertical it catches on some of the throttle parts on the top of the carb to stay up. I don’t see a normal/usual butterfly close inside the carb.
How does this carb choke work to create an increased vacuum inside the throat? What is the action that happens when the choke lever is raised verticle? What parts on the top of the carb change what happens inside the throat?
