Problem: Engine over speeds to roughly 4,500 – 5,500rpm. The dash throtle control has no influence on speed, 0.
Background info:
I changed the gas filter. On the 11/32 that required taking of the gas tank. At the same time I took the carb off and cleaned it. The engine over speeds ever since. I have reset the governor many times along with some jets and stops adjustments to no effect.
Honda 11/32 snowblower. Engine GX340
After a factory manual governor adjust, several times, the engine over speeds.
The setting was:
1 Put the throttle to full speed.
2 Loosen the governor arm screw.
3 Push the gov arm max forward so the butterfly is max open.
4 Turn the governor engine gov adjuster fully clockwise.
With the throttle on the dash off and I move the governor arm with a finger from it’s home position it returns to it’s start position without force but returns. When at full throttle and I move it off its home position snaps back strongly to its home position with a bang, normal.
Starts on the first pull.
Does not change speed with the dash throttle in any position.
Will run at low speed with a little choke. When the choke lever goes from full choke to less choke it over speeds to around 4000, 5000 rmp.
The throttle butterfly never returns to be shut when stopped i.e throttle to very slow.
The spring moved by the throttle cable seems fine not stretched. It goes from an arm controlled by the throttle lever on the dash to the governor. The spring is original and I think in good shape. When the throttle is set to low speed the spring is loose on it’s connections. When the throttle on the dash is set to fast the spring has a lot of pull on the back part of the governor arm.
The spring on the governor that goes from the end of the governor arm to the throttle part on the top of the carb is in excellent shape. The coiled section is not stretched at all. I suspect the governor interals are broken.
The governor controlled butterfly should be closed when the engine is in low throttle but remains open and close to fully open. I have tried all I could to get the butterfly to close when off but unsuccessful. To me that seems like broken internal parts. But that does not make sense as it ran fine before I changed the gas tank spring.
Questions:
When I start it with a little choke and the throttle on the dash set to very low speed
it starts and runs slowly and fine. If I put the throttle to fast there is no response.
If I reduce the throtle there is no speed change. Speed changes only happened with moving the choke lever a little. If I move the choke lever to off it overs speeds immediately.
I am not sure but think the internal arms on startup likely push out a bit to close the throttle to reduce speed. Since that does not happen I suspect the governor internals are broken but don’t see how that happened. Are the governor internals broken?
What carb adjustments could cause extreme rpm’s. I know carb high and low carb adjustments can influence speed buy the range is fairly mild versus extreme.
Background info:
The setting was:
Questions:
