Ok, here’s one more.
So on the weekend I got it running finally after the carb install/no fuel flow issue, and then ran it a bit to warm it up, drained the oil, filled it back with Rotella SAE 30.
When I was trying to get it started, at one point I thought maybe I had flooded it (I hadn’t), so I pulled the plug, and noted later a little puddle of oil on the mower deck under where the spark plug hole is. I had never seen that before…
Since I got it, the oily dirt stain at the head hasn’t changed. I have not cleaned it. It looks like this:
View attachment 222065View attachment 222066View attachment 222067
Makes me wonder if the engine has a weepy head gasket.
And maybe some oil in the cylinder, that doesn’t hydrolock, but also doesn’t burn off? The engine starts first pull after sitting for over a week, it doesn’t smoke, and doesn’t smell particularly bad like a real oil burner might. FWIW
Reason why I show this is because of what else I saw - clean oil residue on the carb bowl. You can see the line on the right side of the bowl. I had it fully clean, so when I looked at that smudge, I realized it was oily.
When I changed the oil, I drained it from the bottom. When I filled it, it went perfectly in the top, no sign of any loss, leaks, certainly didn’t miss, etc.
So why would I have oily residue on the carb bowl? It had to migrate from somewhere. It was clean and slick, so it was fresh new oil like is on the dipstick, not dark dirty brown.
Is this indicative of anything in your experience? Should I do something preemptively? I mean, it’s only a 34 year old air cooled engine… it’s certainly perceivable that a HG or something else is seeping or needs replacement. What typically goes on these?
FSM seems to imply so:
I don’t think it’s enough oil loss to matter. Like a significant burning or anything. I’ll be watching it. I only used this mower last fall, and the patch it mows isn’t huge. But it would be nice to have it running tip top if there is something that is worthwhile to do…
Thanks!!
