I have serious questions about your morals. If I buy 87 I expect 87. If I buy 93 I expect 93Store owner says put this product into that tank-- OK do it-- why is that any concern to the driver?
In some states, I'll bet the tanker driver could be held just as liable as the station owner.Store owner says put this product into that tank-- OK do it-- why is that any concern to the driver?
Now I start worrying if top-tier gas station will actually dump regular gas in their tank...
If you own a Mobil (or pick any top tier franchise) branded station, the Mobil rep can stop in and test the fuel at any time. Any violation of the franchise agreement is BIG trouble for the franchisee.I don't know exactly how that would work. At the fuel depot they'll absolutely make sure that a delivery destined for a specific retailer contains everything required by the marketing agreement. And it's just about additives.
The biggest problem would seem to be with independents who aren't required to have anything except the EPA minimum requirements.
Ohio (at the state level) doesn't do that but there have been proposed laws giving county auditors add'l rights at checking fuel. Currently, they only check that the pumps dispense what they say and maybe water content. They want to check things like octane but don't have that authority.Some of them are starting to do octane testing and alcohol content. Ohio started doing octane checks before I left there 8 years ago. I don't know how well that program has been supported over the years though.
Don't forget the State weights and measures guys. Some of them are starting to do octane testing and alcohol content. Ohio started doing octane checks before I left there 8 years ago. I don't know how well that program has been supported over the years though.
My good friend does this in Michigan. Making sure it dispenses the proper amount and puts those stickers on the pump saying it is certified etc. I don’t however know if they test the octane (he never mentioned that)Don't forget the State weights and measures guys. Some of them are starting to do octane testing and alcohol content. Ohio started doing octane checks before I left there 8 years ago. I don't know how well that program has been supported over the years though.
This is the point that has always concerned me most. Was the driver in a 12-hour long-haul fog when he hooked up the hoses? There's no way to be sure mistakes aren't made. Too bad the ports aren't different from one-another.Interesting.. I know quite a few of our cryo tanker drivers hauled gasoline/diesel at one time or another. I'll have to inquire about this. As far as I know the hoses/connections and fill ports are all the same. It's up to the driver to dispense in the proper hole LOL.
Well they are actually. Most states at least require a color code to be used. All tankers I've seen in recent years have individual drop connections on the tank belly and each of those has a flippable indicator just above it. When the truck is being loaded it is just a simple matter for the driver to flip the indicator to the proper product he is putting in that compartment.Too bad the ports aren't different from one-another.
