Quote:
Is this a dealer/mechanic sort of job? My last several uoa are showing increasing amounts of fuel dilution.
Well, unless you've got a very lazy O2 sensor ..I'd say that it's almost assured that you have leaking injectors. There can be other causes ..but the system should compensate rather well unless you're into only short trip usage.
Use a decent fuel injector cleaner like PI periodically and see if the condition improves. If not, and your O2 is newer, then I'd plan on getting your injectors tested and flow matched (again, we don't know the mileage/age/etc here).
There will be some other "check this" suggestions that are more attuned to your individual engine from those more acquainted with it.
