Looks like major wear on the start of the lobe ramp. Was this wear only on the side of the lobe that hit the lifter first as the cam rotates? If so, then it could be a problem with the case hardening of the metal, and this wear is from the initial impact of the lobe with the lifter as the cam rotated. Could also be related to the cam lobe profile being too aggressive at the start of the lobe ramp, thereby causing high impact force every time the cam started opening the valve. Lack of oiling, and inferior oil use may also be a factor ... could be many factors adding up in the wrong direction.
620,000km (385,000 miles) might have something to do with it also, depending on how this engine was taken care of and driven for that long.
