Originally posted by Eiron:
-snip-
Since I can only change half the fluid each time, I've decided to switch to synthetic & change it every 10k mi.
Keep it PINK and Keep it COOL:
keep it PINK and keep it COOL:
KeEp it Pink and Keep it COOL:
kEeP it Pink and keep it COOL:
Do this and it will last a long time.
Buy a tranny cooler!
As far as changing only 1/2 the fluid, why would you do that? If you mean that 1/2 would stay in the tranny then I'd say to consider a complete flush with those machines,
BG has a tranny flush, and I would suggest their Conditioner too, not just the flush, you may be surprised how long it last, but at least it will get CLOSE to 100% of it out. The service is expensive (??120-150) but if you have it done once, and you can get a salesman from BG, I think you could do the changes with a better fluid (Ithink $32 a gallon). I'm only going by what others have told me, and
the only fluid I have used of theirs is the PowerSteering, and it looks as fresh as when it went in Over 100K ago, and although I'm sure it's gotta be wet by now, the salesman told me that it would go 2-3 times as long as a normal fluid and that their WET was higher than Almost anyones dry on the market and since a normal fluid is usually wet in 1-year or there abouts, then I figure I'm about 1/2 way there.
