ExactlyMuch faster ramps on the roller. More area under the curve for a given lift and duration.
There is no such thing as too much cam. You need more motor. And trans. And Rear. It goes on...
My point is more that this is precisely the kind of cam that is going to be affected by this cam core issue. The mundane and common stuff used in countless engine builds.Absolutely it was a mild cam. The car had a turbo Hydro Matic 400, stock converter, and relatively tall rear end at 273. A cam with more lift and duration would not have been the right fit. That cam was just about perfect. The torque curve created by that cam match the weight, gearing, and stall speed perfectly.
Then, we are in violent agreement.My point is more that this is precisely the kind of cam that is going to be affected by this cam core issue. The mundane and common stuff used in countless engine builds.
I tried to get a Howards American Muscle Cam for an FE a while back, now I guess I know why it's unavailable.
If I ever pull apart one of my classics again I will stab a hydraulic roller and be done with it.Though the cost is much higher for a roller cam due to the higher cost of the roller lifters...it is the way to go these days. The cam is broken in the second it is running.
In what application though?I don't know anyone that runs flat tappets any more. My friends and I have been running rollers for years.
No, but these are all modified cars with modified engines, and I would call them “muscle cars” or “hot rods”.I have a 496" big Mopar. One of my friends just built a stroked 360 Mopar, 410" with a roller. First for him. I have a friend with a 427 in a 67 Chevelle, my brother has a 327 chevy in a 65 Pontiac Tempest that has had a roller in it since the late 80's. I keep bustin' on him to update the valvetrain. He would totally benefit from modern springs and better valvetrain geometry.
Once flat tappets were starting to have problems with the current oil, I viewed them as unreliable.
None of us are running monster drag race cams. I plan on doing Power Tour one day so mine needs to run somewhat like a normal car.
My friend has been wanting to cam swap his 351w in his f150 but quality issues with lifters kept him from pulling the trigger. I told him if he can still find one maybe buy the camshaft now and figure out lifters in the future (hopefully we can find a quality supplier).I already own the next 3 (maybe 4) cams I have planned for my next builds. What I'm hearing in other groups is that there have been some quality issues with lifters coming from 'overseas'. Hopefully we won't be seeing this with the cam cores in the future.
It's going to be too late for my 76 350 olds. Only reason it's still a stock camshaft is originally I didn't have any $, but eventually after 18 years and 130k miles it seems like it will last forever and I don't want to mess with that. This winter it finally got new valve cover gaskets, plugs, belts etc.That was my understanding, too, but the last time I bought a cam was, well, about 1988, and it was a Competition Cams 252 for an Olds 350…
Flat tappet of course. The block was a 1970, and the engine in a 1977.
What about going to a larger cam core diameter and bigger wheel on the roller lifter?you can go more agressive profile with a flat tappet cam, so if a build is that advanced I'm sure the money can be found.
I heard this from several cam companies back 4 months ago when I wanted a stock grind for my 68 Pontiac. I lucked into finding a new cam produced prior to 2007 (Elgin) and replaced the annoying choppy idle cam for a smooth idle. I am holding on to that cam to be reground if needed. FWIW…the majority of the current American manufacturers’ cams (roller) are coming from Mexico. Not sure where the blanks are from though. The issues with todays roller lifters in GM and Stellantis is because of the lack of quality control from these plants south of the border…..Flame suit on!My point is more that this is precisely the kind of cam that is going to be affected by this cam core issue. The mundane and common stuff used in countless engine builds.
Have to machine the block and find new cam bearings--the lobes have to be smaller than the cam journals. Maybe instead reduce the lobe base circle, but I'm sure that brings its own issues (faster ramps, more side loading leading to worse lifter bore wear?).What about going to a larger cam core diameter and bigger wheel on the roller lifter?
Perhaps going for more rocker ratio is a better route.
Question; What is the rocker ratio in the 6.6L LT gasoline engine in a 2500 Chevrolet?
