Patman
Staff member
Also keep in mind though, once that Mobil 1 0w40 shears back to 12 cst, it's HTHS won't be 3.6 anymore, but might be closer to 3.2 to 3.3.
Hmm, how come that Mobil 1 0W-40 meets VW 502 00 and VW 503.01 (requires HTHS 3.5 or higher) then? According to Primus, the HTHS must not fall below the minimum required HTHS, or that oil would not get the car maker's approval. It makes sense that the minimum requirement must be maintained during the whole drain interval. Otherwise the approval is pretty much meaningless.quote:
That's one thing that I wonder too, but it couldn't be technically possible for Mobil 1 0w40 to maintain a 3.5 HTHS for it's entire interval if it is thinning out by 2cst. It's definitely going to be dropping below 3.5 HTHS at some point during the interval if it's only at 3.6 HTHS when new.quote:
Now there's an oil I could use!!quote:
Originally posted by Patman:
... I used to be an Amsoil dealer myself and talked to a few of these guys who would practically tell you this stuff cures baldness. ...
Patman,quote:
Just like I think people shouldn't judge this new Castrol oil based on the antics of the idiots at Castrol USA. Keep in mind, they don't even make the stuff.
I only recall one UOA where this oil dropped below 11 cst and the rest have all been in the range of 11.0 to 11.5. Also keep in mind that in many of these used oil analysis, the person switched from a thinner oil, so their first run of GC will be mixed in with that, so it'll show a thinner viscosity than it would in subsequent intervals.quote:
Out of the four EC 0w30 used oil analysis I could find with viscosity numbers (did minrek ever come up with a vis for his F150?), I came up with a mean viscosity of 10.73 over 18,727 miles, or an 11.25% drop in viscosity from the 12.1cSt starting point.
how true this is.quote:
There are many forums on the internet and these are often the result of seemingly knowledgeable persons offering so called "expert information"
to those that aren't.
Unfortunately many Amsoil dealers fall into this same category too. We're lucky none of ours on here are like that, but there are tons of them out there in the real world and on the net who give out all kinds of false info. Even Amsoil's own website is guilty of that too.quote:
I totally agree, and that's why this site exists, so we can seperate the advertising hype from the truth. used oil analysis are the truth.quote:
Originally posted by Pablo:
ALL oil companies make some wild claims.
Have we really done that though or just created a ton of info via used oil analysis that is extremely difficult to interpret. By that I mean we are unable to look at Valvoline 10W30 produced in 2002 and say that it does or does not do well over 3000 mile intervals in this climate, in city driving etc. We have tons of data but true confusion. Unfortunately, Blackstone has all the info on a huge array of oils and conditions that could be used to provide insight but legally they would never publish this. This site has similar info but not in any format. It would be fantastic to go to a site, input Castrol GTX, 10W30 2002 formula and see all the used oil analysis and explanations and the reader could determine if that oil fits his bill. True facts and no opinions, just data.quote:
I totally agree, and that's why this site exists, so we can seperate the advertising hype from the truth. used oil analysis are the truth. [/QB]
I'd guess the same conditions apply to the Mobil 1 0W-40 used oil analysis I used, where the person was switching from an xW-30 to give 0W-40 a try.quote:
Also note that the VOAs on this oil show it starting at 11.6 to 11.8 cst. So your thinning percentage is off just based on that alone.
