Originally Posted By: A_Harman
Originally Posted By: Olas
Horsepower doesn't exist, it's a notional way to express torque over time.
That said, I regularly use as much torque in a give time as possible
Power is
the rate at which work is done, whether it's expressed in kW or HP.
It is the product of effort and flow.
In electricity, it is Voltage x Current.
In hydraulics and pneumatics, it is Pressure x Mass Flow
In linear motion, it is Force x Speed.
In rotary motion, it is Torque x Rotation Rate.
The way that you get from torque and rotation rate to HP is:
950 ft* lbs x 2700 rev/min x 2pi radians/rev x 1 HP/550 ft*lbs/sec x 1 min/60 sec = 488 HP.
The amount of work that that engine does in one rotation is 950 ft*lbs x 2pi rad/rev = 5969 ft*lbs
James Watt is the one who defined the unit of "Horsepower", which he obtained by measuring how much work a horse could do in a given amount of time while operating a turnstile pumping water out of a coal mine. He measured the effort of the horse at 180 pounds, and the speed at 181 ft/min, multiplied them to get 32,580 ft*lb/min, rounded to 33,000, and called it a Horsepower. When the Metric system was defined, they honored James Watt by calling the unit of power a "Watt".
Absolutely right
I couldn't go to the effort To type all that out but it's what I was getting at, hoping for a reply from the op
