Originally Posted By: mightymousetech
Originally Posted By: parshisa
There's absolutely nothing special about the factory fill (average additive package with high moly from the lube used to build the engine). Engine break in occurs within first hours of it's work and it is likely broken in before you drive off the lot. Just watch the condition of the oil. Not sure what honda you drive but if it is Turbocharged beware of fuel dilution. My oil was done by 4K. It was badly diluted, sheared and low on viscosity. Just common sense. There's nothing special about these mass produced cars. Cheers
Honda's official position is that doing the first oil change early can cause engine damage. We will not change the oil for the first time until it gets down to at least 20%.
After that, change it every month if you want.
To be fair, it's awfully hard to find this language from Honda anywhere now. It certainly isn't in the Owner's Manual and I think it's gone from the FAQ section of Honda's website. The recommendation may be out there somewhere, but it isn't obvious, service departments seem to have never heard of it and most owners are oblivious.
My question was more of a theoretical one: if this was Honda's position, why was it so important and what benefit did molybdenum provide after a couple thousand miles?
Our service bulletins are where this info is located. The bulletin states changing the oil too early can cause hot spots to form in the engine, which can damage it. We get a new version of the bulletin every couple of years.
Will not be in the owners manual, because Honda just expects the customer to follow the maintenance minder.
So my "molybdenum prevents hot spots during break-in" theory was correct? Gee...
If it's really that important though, Honda should emphasize it more: I'll bet a good number of owners still follow the early ff change routine thinking it's beneficial. And with modern Honda engines being really good at fuel dilution, knowing what to do is not entirely clear.
Thanks for the info.
