I'm using Havoline synthetic 0w20 in my hybrid Accord because it's the cheapest readily available synthetic.Any major brand of 0w-20 will be fine. I would go with 5000 mile oil change intervals.
I was a tech at Honda. We did not recommend going past 5,000 miles on oil. All consumers fall under the extreme service. the oil smells of fuel when drained. Honda doesn’t use full synthetic for service. It is Honda branded synthetic blend 0w20 which is made by ConocoPhillips, as is all of Hondas lubricants. There was some customers that provided their own oil which was typically 5w30, or Mobil 1 0w20EP.
Use the Honda filters purchased from a Honda dealership and change oil at 3K if you are wanting to keep this car a looong time. I’d use the Honda oil unless it is way higher than other top grades.
That’s the only way I change my oil. I have never taken the drain plug out. I have a schwaben oil extractor 6.5 liter. What oil are you usingIf it’s possible to do a “top-side” oil change using an extractor, with a 3k interval no reason a Honda filter couldn’t be left in place for 3 or more oil changes.
This is not true, for Europe transmission oil and engine oil only come from idemitsu. The honda Engine Type 2.0 0W20 was developed purely for Honda.I was a tech at Honda. We did not recommend going past 5,000 miles on oil. All consumers fall under the extreme service. the oil smells of fuel when drained. Honda doesn’t use full synthetic for service. It is Honda branded synthetic blend 0w20 which is made by ConocoPhillips, as is all of Hondas lubricants. There was some customers that provided their own oil which was typically 5w30, or Mobil 1 0w20EP.
Okay. I’m in United States! In United States ConocoPhillips is the lubricants supplier for Honda America.This is not true, for Europe transmission oil and engine oil only come from idemitsu. The honda Engine Type 2.0 0W20 was developed purely for Honda.
Go read some of the post on these forums. Oil brand absolutely makes a difference. I only listen to select people on here when it comes to oil brands, base stock makeup and other info.I have a Honda 2.4 DI engine so fuel dilution isn’t as troublesome as the 1.5T. Since new I’ve been using either Mobil1 or Valvoline full syn with 5k or shorter OCIs. I think I’ve convinced myself oil brand isn’t quite so important and may move to QS full synthetic.
You not in USA?Few Honda dealers actually use Honda oils. Mine was using Castrol Magnatec for a while, now uses Petro-Canada, with probably a few others in between. Oddly, cost seems to be a consideration…
You not in USA?
I’m just asking bc it’s funny how different dealers use different oils in different parts of states.Smack dab in the middle of the USA.
All the reading I do on here, Mobil 1 FS 0w40Spend some time on BITOG. Consensus is as long as an oil meets specs (e.g. SP, Dexos 1 Gen3). And people frequently misuse used oil analysis results: they really tell the condition of the oil, not the engine.
TGMO 0W-20 SPOnly being slightly picky here because this is my first new car, 2022 Civic Sport Touring, 1.5L Direct Injected Turbo CVT. I'm not a crazy driver, normally used Mobil 1 Advanced Fuel Economy in my old 2012 Prius just fine. Plan to use the Honda 15400 factory filters either way, but wondering if I should go out of my way to run the Honda Ultimate 0w-20 or stuff like Mobil is close enough not to bother. I drive 10-12000 miles per year, willing to change the oil more often but looking to minimize the inherent issues that these DI Turbo engines can sometimes have (oil dilution, carbon buildup). I was told to look for something with a GF-6 or GF-6a rating, which the Mobil advanced fuel economy does have.
I remember not long ago there is a topic on this stuff not being very good. The better oil was Mobil 1 X2 0w20.TGMO 0W-20 SP
It is made by ExxonMobil, has high moly (AW/EP/FM), high boron (dispersant), high ZDDP (AW), and polyol ester ((POE) deposit solvent).
You would be paying X2 or X3 for Mobil 1 X2 0W-20 with no scientifically measurable performance difference—X2 indeed.I remember not long ago there is a topic on this stuff not being very good. The better oil was Mobil 1 X2 0w20.
