Honda push mower engine oil 10w30
You can use any high quality conventional or synthetic oil.
I use Shell 10w30 in my HRX-217 because I bought some at $.59/quart.
My mower takes 14.5 oz at drain and fill, so 1 quart is good for 2 changes.
personally, Id run a syn 30wt or 10w30. M1 is good, Amsoil ACD is my choice.
If going conventional, Id look for an HDEO 10w30.
These engines hold very little oil so even a very expensive synthetic oil will not break the bank.
Mobil 1 10w30 is good and easy to get. Change it 2x per season and you will be in great shape.
break in is 5-10 hours and you can switch to syn at 10 hours no problem, fact is that air filtration is the much bigger factor and with a good conventional oil that mower will last 15 years no problem.
About any 10-30 will work in one of those well-designed engines.
Rotella T 10-30 is a good one. Probably overkill for a mower, but, that's why we're here, right?
