Still a ways off, but trying to decide if I should DIY or farm it out. Aisin timing belt kit with the belt, tensioners, and water pump is about $100. Much better than the ball park figure the dealer quoted. I've pulled engines, helped replace the timing gear on a GM Iron Duke, replaced an MG Midget clutch myself, and I think this is within my capabilities. Only things that concern me are the crank pulley bolt, and the nagging feeling of "what if something goes wrong" or worse, "what if something goes wrong a few thousand miles later that causes the timing belt to fail and wrecks the engine". Looks like the heavy mass impact socket with my air impact wrench would do the trick for the bolt, and I would buy the crank holding tool to make sure it doesn't go anywhere when tightening it. Youtube videos look pretty straightforward.
