Originally Posted By: blackman777
You forgot about the insight and civic hybrids running 0w-20 since 2000 and 2001. (shrug) I guess you thought I was fibbing. Whatever.
For a guy who's first few posts were:
Delvac 1 is only 3 time s thicket than the 5w-20. Go ahead.
Currently running Mobil Super synthetic. Is there any advantage to running a Blended oil that is a mixed natural and synthetic oil? Does that % of natural oil pulled from Arabia provide any extra protection that pure synthoil (from a lab) does not provide?
find it funny that people think the original poster is lying. Cars DO sometimes have sudden failures. Maybe a seal burst open internally, and the great-running car started losing a quart of oil every 200 miles. It isn't inconceivable. It doesn't mean the OP is lying.
I had a Saturn that was dead within a month. It started by losing power on the highway (top speed 70). The mechanic looked at it & said cylinder 2 had lost compression; bad seal. I kept driving until it died abut 5 weeks later. Towed it to the garage and he said now 2 cylinders lost compression. Cars sometimes die suddenly. (Now I guess yu'l accuse me of lying too.)
(2) Looking at the used oil analyses it amazes me that you guys run 20,000 miles. That guy with the S2000 went 40,000 miles!
(3) It looks to me that long oil changes are NOT a problem and don;t see why you Linearray Nut think they are. Or why you're hating on the guy just because he posted his oil analysis. Over in Europe new cars are told to go 20,000 miles between changes, and the manufacturer would not make the recommendation if it were not possible. (Well maybe tey would if they wanted to kill cars & sell more units; but I doubt it.)
Meets the requirements of _____. Does it say dexos or some obscure GM1999-type number?
What's the diff between Group 3 and 3+ oil?
Which should I use for a brand-new Chevy Equinox V6. Oh and it has an oil change indicator. Does tht thing actually monitor the oil quality? How does it do that? With a sensor? I'm inclined to ignore it and just do 7500 miles each time (like my old 1999 Chevy).
Oh and I've always used Pennzoil conventional oil, so I'm leaning that way.
Then:
So that's 12,000 miles. The problem with the oil life "monitor" is that it assumes the engine is working perfectly. As the engine ages (200,000 miles) it will not be running as clean, and the oil will be getting dirty faster, but the OLM will still be calculating 12,000 miles, even though the oil is full of engine blowby & wore-out at 7000.
I have a Honda, and while it says 0w-20 is preferred, it also says 5w-20 or 5w30 can be run without voiding the warranty. I suspect your Civic is the same.
RedLine's SAE20 oil has no viscosity modifiers and yet it is a 5W-20 by default. And Amsoil told me via email that its 0w-20 has viscosity modifiers, but its 5w-20 has none (hence a lower pricetag). I think it would be a good guess that the other brands (Mobil, Pennzoil, etc) have no VIMs in their 5w-20s too. Or else very close to zero.
I would rather use a 5w-20 that has no VIMs than the 0w-20 that has them. That way I avoid VIM burn-off that coats the internals with varnish. Which is why I don't understand why many posters here are enamored with the 0W oils.
IMHO
You've gone from apparently not having a clue to speaking with authority on many subjects on this board. So, are we being trolled or what's the story here?
