Honda Element - differential ???
FL
Need help on this one... A friend has a Honda Element and started to hear a grinding noise coming from the rear of vehicle and recently had a tire replaced so naturally he took it back to the tire dealer/mechanic. They said they the tires were fine but did find metal flake in the differential and to fix the problem they would have to replace it at a cost of $900.
This is were somethings not adding up... Isn't the Element front wheel drive and the differential house in the transmission?
I know it's not a lot of information, any insight would be appreciated.
Rear Differential Fluid on 4WD is very easy to change. Since you have the grinding noise you should probably do the burnish process too.
Here is a link to how to do the change and pics.
This change is shown on a CR-V, but it is the same thing. This one is in more detail.
If you don't want to do the change yourself, a Honda dealer will do the change and burnishing process from anywhere from $80-$200, depending on your dealer and where you live.
Easy way to tell if its 4WD:
1. Has RealTime 4WD sticker on back windshield. ('03-'09)
2. Has Sunroof in the rear ('03-'09)
3. Has 4WD emblem on back tailgate ('10-'11)
I had an Element before so if you have any other questions I can try and help you out.
It's easy. I've done it 3 times on my CR-V of the same ilk. Get a 1-quart bottle pump to pump the proper fluid into the fill hole. Do the fluid change and see how it goes first. The Dual Pump fluid is known to have a shorter life than the manual's spec'd 60k runs.
