I just changed oil on my 03 Civic at 3,300 miles. I really wasn't that dirty and wasn't as "thin" as I was expecting. I put in 5w20 Pennzoil and will change at 7,000 and maybe do an analysis on the next batch.
Cast iron is a different material than steel and has different wear-in properties. For one thing, steel is more ductile than iron. I think this is where the moly comes in.quote:
Originally posted by slickracer:
Jay, they were Chevrolet's which are cast iron blocks. So the pistons are riding in the same type of bore.
quote:
I've been some research into this. The reason for S2k's burning more oil than normal Vtec's during run in is due to the construction of the block. It's fibre reinforced aluminium, which is very strong and light, but it's requiring longer for the pistol rings to get a perfect seal.
The concensus is that the break in oil is very high in molybdenum - the idea being that this fills in the very tiny scratches in the bore to provide a good seal for the piston rings. So the high oil consumption is oil getting past the piston ring and bruning off - but this is what you want, as over time the seal will settle.
Keep your oil topped up and comsuption should drop off to pretty much zero by your first service, if not long before. Do take care not to over fill though - Vtec runs off oil pressure, but overfilling can be very dangerous for the engine.
As to the exact oil to put in.... nobody seems to have a definitive answer. Certainly it's a bad idea to change to fully synthetic oil until the engine has bedded in (at least 7,000 miles seems to be the concensus), but for top up? I don't think it's going to matter as the percentage of new oil should still be pretty low.
Which Honda engines still use iron sleeves?quote:
quote:
In 1990,Honda launched a new generation of
aluminum engine blocks with fibre reinforced cylinder
walls replacing traditional cast iron liners.The first
model selected for production was the Prelude Si,a
16 valve in-line 4-cylinder engine,using a new
casting process to incorporate the Saffil -carbon fibre
hybrid preforms.
Elimination of he cast iron liner using MMC
technology allows a reduction in material thickness
between the adjacent bores.Tightening the cylinder
spacing in this way results in reduction in he overall
length of the engine and a weight saving on the block
of around 4.5kg.
Honda has since expanded the use of MMC engine
blocks and include models of the Accord,Ascot
Innova and the S2000.
if your stock si dynoed 170whp theres something wrong with the shops dyno. i owned an si as well, '00 insted of '99 though. those cars put down 140hp to the wheels and 160 at the flywheel.. if its 170hp at the flywheel.. thats more believablequote:
Originally posted by Chris Jefferson:
I used to own a 99' Honda Civic Si(R) that had the B16A2 DOHC VTEC engine and (it produced 160hp but it was really 170hp i dynoed it)i too changed the oil at like 600miles and found out i couldnt budge the filter (after id already drained the oil).
Correct.quote:
Kreigle, I'm not sure if your question was directed to me because I never said, nor implied, that Honda uses cast iron cylinder sleeves--just the opposite, I said they use steel sleeves in their K20A2, K20A3, and many of their 4 cylinder engines. The S2000 does use the metal matrix block, so do many of their motorcycle engines.
Thanks for the link to saffil.
How many cars are still made in Japan.quote:
Originally posted by Ken2:
You should see how the longshoremen drive the cars when they're loading the car carrier shipsquote:
Originally posted by JohnBrowning:
The first 20 minutes are the hardest on the engine.
Especially in Japan they're often young and drive like they're in the Harbor Grand Prix!
Ken
Originally posted by GSV:
PS - I once worked at a car rental agency and the employees absolutely positively HAMMER the cars. Handbrake turns, J-hooks, four wheel power slides through grass and mud, full throttle acceleration in cars with 10 miles on the odometer...
I'm a much mellower driver after scaring myself silly 700 times working at that place.
Another reason to NEVER buy a used car from a Rental Agency!!!
I would never buy a Rental Car, either. In my younger years I abused every rental car I rented. Blown tires, e brakes broken, but mostly driven like it was stolen. I remember one particular GM model we blew the airbags out and the entire front window. (During an offroad excursion) ALWAYS get the rental insurance!quote:
I know this is going to sound "smart alec," but here goes anyway: report back in another 100k miles, and then I'll be impressed.quote:
Originally posted by Bela:
My 2001 Accord EX V6 had the first oil change at 7500 miles (as recommended for normal driving) by my Honda dealer. It now has 43981 miles and uses no oil.
