Originally Posted By: rationull
This is interesting and somewhat discouraging if the problem turns out to be the filter. Honda's maintenance recommendation is to change the oil filter every other oil change which works out from 10k miles to up to 20k miles depending on driving conditions. They've been recommending this for years. Doesn't seem like the filter should plug up as low as 12-13k.
That recommendation is made with the OEM filter in mind. If you're using a non-OEM filter, you should probably stick with the recommendation on the filter. My guess is that the high efficiency Amsoil filter loads up more quickly than the lower-efficiency OEM filter. I've never heard of anyone using an OEM filter for 2 OCI's and having the oil pressure light come on.
