Originally Posted By: Market525
pbm,
I've done this job on the 2.3L Accord numerous times, so I wanted to add a few points.
Crankshaft holding tool - google SP Tools 60100A and you'll get many hits. The tool runs around $50. Buy it & don't look back if you are doing this job yourself. SP stands for Schely Products.
Even the Haynes manual shows using a strap wrench to hold the CS pully. They are nuts. This SP tool, so similar, is a MUST HAVE. Torque on that bolt is 181 ft lbs.
You'll also need two 1/2 inch breaker bars, and two lengths of pipe. I think mine are 12" and 18". You'll also need some 1/2 inch extensions. My experience says that you'll need impact wrench quality extensions - not regular duty. Once you set all the tools up & put your full body weight on that breaker bar & pipe, you'll see what I mean if you don't have impact extensions. At times I have even used a propane tourch to heat the bolt for a minute or so prior to trying to remove it. Once you get this bolt off, the rest of the job is all downhill.
A post above mentioned they sometimes found a missing timing belt tensioner? This is impossible. He must have his cars confused. The same posted mentions snugging up the belt to proper tension. This is also wrong. On the balancer belt, the spring provides the proper tension. On the timing belt, the manual (Honda or Haynes) has very specific instructions on how to attain final TB tension. Follow the book. There simply is no *snugging it up* as he describes.
Balancer belt - just replace it. The Honda part number is 13405-PAA-A03 and wholesale price is $15.76. Why on earth would you not replace it? And someone earlier said leave it off? I hope that was a joke.
A good source for OEM Honda parts, great prices, and quick shipping is Majestic Honda located in Rhode Island. Website -
http://www.hondaautomotiveparts.com. I have used them with much success for years now.
You asked about the interval - yes it is realistic. 105K or 7 years is what Honda states. You are due by years if not by mileage.
Several opinions offered here to you on seals ... I'll only say that I have them on hand, but at the first TB change - 105K - I personally do not change them unless I see one seeping or leaking. To this point, I've never seen one leaking. Again, your call.
At that mileage, I always do timing belt, balancer belt, water pump, plug wires, plugs (irridiums - and yes they are expensive - $12 each or so) PCV valve, spark plug tube seals, both power steering and alt/AC belts, VC gasket, and clean the throttle body. Car will be good for another 100K.
Oh - and you'll have to remove the underside splash pan to do this job. You'll most likely break a few of those push-type clips -- be prepared with a couple of replacments as you are buying the parts you need.
Takes me about 6 solid hours. Someone ealier said they could do the book time - no way I could.
Good luck on the job!
Steve
You've mis read my post. The bolt I am describing is bolt the secures the tensioner. The tensioner is NOT missing. The small 10mm bolt that hold the tensioner in a certain position is what I see missing alot.
I beg to differ on the belt tension you've described as "wrong". If you rely on the 2 little spings (each spring for each tensioner)you'll have a very very loose timing belt and balance shaft belt. Infact the balance shaft belt's "tensioning spring" is EXTREMELY loose from new. Any experienced auto tech would agree with me that using a spring as the "guage" for tension is Ridiculous.
I dont know one professional auto tech owning a timing belt tensioner guage. Experience dictates never to use a "spring" to assure proper tension.
Your reference to the haynes manual already indicates questionable information. Haynes is one of the most poor references you can use. Mitchell on demand has cost my bro/my shop over 15,000 CDN from day one to updates. Not a 20 dollar manual printed on recycled paper.
People can take info on the net with a grain of salt. I have no benefits typing info to help others. I hope my many years of experience helps a noob.
A full on job with seals, waterpump, vc gasket, tbelt, balance shaft belt, drive belts etc etc can easily be done within 4.5 hours with no shortcuts. I take pride in my work and customers do not come back. Experience and knowledge differentiates a good mechanic to a not so good.
I fell off my chair when i read someone using the springs as the "proper" tension. Little knowledge is a dangerous tool. Market525 be careful with your weapon.
