Like cptbarkley stated, use the AISIN timing belt kit if you don't use Honda OEM parts. The Gates kits are now garbage, especially the water pump. While the Honda OEM timing belt is made by UNITTA (i.e., Gates Japan factory), the belt that comes in the Gates kit is of lower quality than the OEM UNITTA. The AISIN kit will contain a Mitsuboshi belt (which is OEM on older Honda models), an AISIN water pump & tensioner and Koyo bearings. The parts you need are also available on Amazon, including the spark plugs, but may be less costly on RockAuto.Need to order the kit, find spark plugs (which Amazon and several places don’t carry for 02 Accord), serpentine belt, coolant (I recall having to change it out last time when doing belt and water pump, and check to see if I need brake pads too.
NGK LASER PLATINUM PLUGS
NGK COPPER SPARK PLUGS
