High Torque CVT - Engineering Explained
Amazing. My head hurts, then I was made even more annoyed that I thought this was brand new technology....since 1999 ?
Is this special fluid $1000 per litre? made from free-range bed frame molecules?
Nissan and Jatco had this out since the mid-2000s but it never saw deployment in a Infiniti or the JDM versions(Fuga and Skyline). It's a toroidal CVT that can take more power than a chain/belt based one.
I could see Subaru using this in an refresh of the Legacy/Outback/Ascent.
It is still metal on metal contact. The difference is that this new arrangement can essentially have two cones dividing the torque between them. Throughout the majority of the video I kept thinking how they will cope with the friction forces as the contact area is even less than that of a CVT belt and that metal on metal contact, until he mentioned the special fluid. Basically it all rides on this fluid. I can only guess that Nissan will claim this a lifetime fluid as well.
Ya know, I don't have any trouble with my CVT and I do like it very much however, Nissan/JATCO needs to get their "You Know What" together.
From my understanding, CVTs are quite a simple design. But then why are they so trouble prone.
They are simple but very fussy if they don't have the right amount of friction and the high oil pressure to keep it engaged in the band type.
Any suggestion to keeping them in tip-top condition?
Interesting, I'll have to watch the video. Thanks for sharing.
I will say this, I drove the Subaru WRX with the CVT in sport mode using the paddle shifters and it was a blast to drive. Far better than the manual transmission.
Change the fluid often and don't overheat them. That's the best advice. I would steer clear for Jatco / Nissan type although they are better and have better fluid than the first generation NS-3 is supposed to be good stuff according to Terry. Honda seems fine with a BITOG member here have 200K miles on his but he changes the fluid frequently, Toyota are fine and later Ford are fine, Subaru I think still has some bugs IMO with some being ok and others failing early.
That's funny...
My Nissan Altima VQ 3.5 with CVT is real close to 250k miles on the original CVT fluid... I'm not all too concerned either
It is a combination with the motor that matters a lot as well. Also... The computer programming matter quite a bit I believe.
NS-2 fluid by the way... It must not be total junk
Originally Posted by bbhero
That's funny...
If you ever stop by Northern CA, I will change it for you for free so that I can grab a sample for a UOA.
Yeah could do that
In all seriousness I will pull some out and add some new to it... Got to get a fluid evacuator for that coming up.
Automatics and CVTs are catching up fast - Toyota uses a tweaked version of their 8-speed behind the 2UR-GSE V8 in the F(not F Sport) variants of the IS/GS/RC and the LC500, the ZF 8HP70/90 is finding use in high-powered Mopar SRTs and Euro cars(R-spec Jags, blown Range Rovers and fast but heavy Bentleys and Rolls come to mind). Mercedes is using their 7G/9G-Tronic without a torque converter in their AMG cars.
That's funny...
You got lucky as did a previous work colleague of mine that had the Jatco in his Caliber and it was all original at 300K KM.
I don't think it's luck.....
Operation conditions are favorable... Long highway runs... Temp low throughout doing that....
She does get a bit warm I guess when I go hammer down... But that is like only 1% of the distance driven.
Plus... The motor matters as well.... The 3.5s do better with CVT vs the 2.5s.. The bigger motors keep transmission in better operating band I believe.
I remember reading about these toroidal CVTs years ago for the automotive realm. It's got to be a high cost situation at present or they would have taken over the belt/chain CVTs by now.
No it not actually. It is s special fluid that transmits the torque. There is no metal to metal contact in a well executed CVT transmission. The "tech" is all in the traction fluid.
Hence my last mention that it all rides on the fluid. Otherwise it's full metal to metal contact, just like with the steel belt CVTs. The moment that fluid overheats and shears down, the transmission is toast in quick order.
