OVERKILL
$100 Site Donor 2021
Boy would I ever like to see a UOA that would prove that myth!
Sample 2 is VOA, Sample 3 is after 10,876km.
Good that you shared this one with not many miles otherwise they would say that the oil has gotten very bad and thick, while this is not the usual bad thickening(Oxidation won against shear). Like if you tell people that this oil is Pennzoil 0W-20, then it looks very very bad, just like a pile of 3 years and 20,000 miles old oxidized crap.
A UOA wouldn’t tell you that. A KRL test would.Boy would I ever like to see a UOA that would prove that myth!
What was Sample 1?
Mobil 1 he mentions in the previous VOAWhat was Sample 1?
Ram chewed Mobil 1's best to 8.0What was Sample 1?
M1 EP 0W-20.What was Sample 1?
How would you define "3W" as a Winter grade that would make it any different from 0W or 5W? Same goes with "28", that's a very specific number, while grades are ranges, I'm not really following the logic here?Looking at all those oil viscosity choices it made me think, if we don't stick with numbers like 0, 5, 10 etc, would it be easier to mix an oil like say 3w-28 that would be also better in several aspects than 0w-25 or 5w-30?
Yeah. And what do we get if we mix 2 quarts of 5W-30 and 0W-20? Will they even harmlessly mix?I should have mentioned oils like 0w-8, 0w-12 (I thought it existed) and 0w-16, they are not numbers with a multiplier of 5. That's what I was sorta thinking. Taking it further, the numbers don't need to be even ether. Some people mix store bought oils of different viscosities and those blends should result in making quite odd oils, what if they were offered by producers?
SAE 8, 12 and 16 were broken out of SAE 20, so they are all narrower bands than SAE 30/40/50/60.I should have mentioned oils like 0w-8, 0w-12 (I thought it existed) and 0w-16, they are not numbers with a multiplier of 5. That's what I was sorta thinking. Taking it further, the numbers don't need to be even ether. Some people mix store bought oils of different viscosities and those blends should result in making quite odd oils, what if they were offered by producers?
No, because those numbers cover a range of viscosities. The grades are established and there’s no “dead space” between the grades.Looking at all those oil viscosity choices it made me think, if we don't stick with numbers like 0, 5, 10 etc, would it be easier to mix an oil like say 3w-28 that would be also better in several aspects than 0w-25 or 5w-30?
EP went from 8.8cSt to 8.0, SC went from 8.5 to 9.5cSt. So EP lost almost 1cSt, and SC gained 1cSt.So the M1 EP 0W20 was at 8 KV100 which is close the virgin I think. But the other oil increased by 1 and oxidation almost doubled?
I’d much rather have an oil that has a known, gradual increase in viscosity even in the presence of some fuel dilution, rather than an oil that may suffer permanent shear AND quickly thin with fuel dilution. There’s zero harm for a slight viscosity increase; dropping out of grade can carry serious implications for chain life, bearing health, and contact points like finger rollers and pushrod cups.EP went from 8.8cSt to 8.0, SC went from 8.5 to 9.5cSt. So EP lost almost 1cSt, and SC gained 1cSt.
Why did the HPL Super Car oxidation go into the red zone in the UOA? The OCI wasn't that much longer than the M1 in Sample 1.
Because they failed to account for virgin oxidation unfortunately, the VOA isn't flagged as a VOA (BL)Why did the HPL Super Car oxidation go into the red zone in the UOA? The OCI wasn't that much longer than the M1 in Sample 1.
Why is the virgin oxidation on the HPL SC higher than the UOA oxidation on the M1?Because they failed to account for virgin oxidation unfortunately, the VOA isn't flagged as a VOA (BL)
