Thanks for the update!800 mile update: So far things seem to be going good wouldn’t say the oil is any darker than 600 miles ago haven’t noticed anything abnormal engine seems to be running just as smooth as it always has, the visible varnish under the oil fill cap doesn’t appear to have changed any, will be changing the filter out at 2k miles and replacing it with another Fram Ultra.
Both ester cleanersIt’s weird…we haven’t had this level of interest or discussion about an engine cleaner since auto-rx was a favourite here…
Does HPL Engine Cleaner also help clean carbon from rings? I wonder how using this as recommended would compare to Valvoline Premium Blue Restore?
Ordered a six pack, going to jump into this experiment and see how good this cleans a high mileage engine that had regular OCI with but with bulk oils. Just put Mobil 1 High Mileage (Supposed to clean in one OCI) in it for a 3K to 4K OCI, after about 2000 Miles will change filter just in-case any major stuff was loosened by Mobil 1 High Mileage, and add EC for the remaining 2000 miles.Yes. The high solubility and high temperature stability of the ester allows it to clean well around the rings. I works in a similar way to VPBR.
Can I get a contact info so I can purchase a bottleSince the topic has come up a few times I am posting the PDS in the PCMO, Diesel, and Euro sections. This is a safe path to clean varnish and or sludge left behind by other oils. There are no solvents in this oil. It has enough ester to clean but still be safe with elastomers. Simply add a quart to the current oil and can be used for 1-2,000 miles preferably but can be run longer if needed. Changing a filter at 2,000 miles is recommended should you wish to clean further.
Interesting, does HPL market the product for that kind of use?Ordered a six pack, going to jump into this experiment and see how good this cleans a high mileage engine that had regular OCI with but with bulk oils. Just put Mobil 1 High Mileage (Supposed to clean in one OCI) in it for a 3K to 4K OCI, after about 2000 Miles will change filter just in-case any major stuff was loosened by Mobil 1 High Mileage, and add EC for the remaining 2000 miles.
If it works will going forward will add a few oz, toward the end of every OCI to maintain cleanliness and boost cleaning power of oil.
Just because they don't market it that way why wouldn't it work? Similar to people adding techron to their gas, when chevron gas already contains techron. According to HPL, EC is mostly esters so how could it hurt? Granted the concentration may may be not in the super cleaning strength it was designed for, worse case it does nothing and I wasted my money, but on the flip side, if it works, then I get a super clean engine.Interesting, does HPL market the product for that kind of use?
