Originally Posted By: firebird72
yes i always do a cool down for a couple minutes if driven hard & also drive easy for the last 5-10 minutes.
Originally Posted By: jayg
Old school oil lubrication for that journal bearing should have at least a 40 wt oil to wick away heat. My recommendation would be M1 HM 10w40 or if you have no noticeable consumption or leaks, M1 15w50.
curious what you are basing that oil weight suggestion on? the car calls for straight 30 weight oil unless driven in temps below 40* then it calls for 10/30. back in the 80's GM's solution to avoiding coking was thicker oils but todays oils are much better & most all 10/30 oils will be ok for street use. i live in the midwest & the car gets driven or started in 40* & below days, the engine has very low miles & zero consumption or burning... so please explain why i would want or need a 10/40 or expecially a 15/50 oil for this car??? also, why does thicker oil "wick away heat?" always read that thinner oils, to a poaint, are better for coooling since they flow better around bearing etc... flow equals cooling, not thickness.
I guess the car calls for straight 30 as early multigrades were prone to shearing, and an 1980s 10w-30 or 10w-40 would relatively fast have an HTHS of "too low". But a quality modern oil should not have these issues any more.
Originally Posted By: UltrafanUK
2 or 3 minutes is enough to avoid hot shutdown damage to the turbo bearings in most older vehicles. Modern ones have a follow on electric oil puimp.
Cold starting with your boot on the accelerator causing a sudden jump in the revs as the engine fires up is more of a bearing killer.
It really isn't though. In an older vehicle that is water and oil cooled then yes but the idle oil pressure on a strictly oil cooled turbo BOP that isn't enough to avoid coking. I've had so many old school turbo vehicles and I've learned the hard way on tricks to make them last.
On my previous Saab 900 turbo 8V (Garrett T3, only oil - no water), the turbo would take roughly 5 minutes at idle after a spirited short Autobahn drive just to go from "bright orange" to "no longer visibly glowing" (at daylight). You really had to take your time to cool this car down before shutting it off.
On my more modern 16V with electronic fuel injection and deceleration fuel cut-off, this is much easier. I use downshift and engine breaking as I go from 5th to 2nd gear to pump cool air through the engine when on the off-ramp, and then I let her idle 30 second, so that the turbo does not spin as fast when shut the engine off. A guy in the german Saab forum who, besides being a Saab enthusiast, happens to be an engine developer for an automotive engineering contractor once did some test runs with several different engines, in which he simulated driving under full load, and then several downshifts an deceleration fuel cut-off until stand still. Deceleartion cut-off and engine braking through several gears brought down temperatures from to 300-400°C relatively quickly, and while further idling took down temperatures further, it did so only very slow and the absalute temperature decreases where minuscule.
Obviuosly that is only going to work with deceleration fuel cut-off, so in a mechanical fuel injection or carburator car, nothing beats calm driving and looong idling.
Looks like the image isnt showing up now. Here is the VOA specs for Maxlife HDD 15w40. Strong Zinc numbers. Do you daily drive this or park it outside? If not, I wouldn't hesitate to run it year round.
no daily driving, its a fair weather driver & a garage queen. but again, 15/40 is too thick for any use or purpose of this car & where i live. it calls for 10/30 & is occasionally driven/started in colder temps. while it looks like a great oil, i just dont see the need for a thick HDEO in it. maxlife will be more than enough.
personally, i`d go with mobil-1 10W30 high millage oil.
also a very good oil choice... but why would you go with full synthetic in this car when it sees under 500 miles a year & has a slow rear main leak? waste of money IMO & could make the leak worse, a full synthetic or thick HDEO just isnt needed. if i started driving it 1500-2000 miles each season &/or turned up the boost & started hot rodding it i would agree with a step up in oil... but for what the car does now, a standard or blend HM oil is perfectly fine.
my main concern was the turbo seals & using HM oil... & that has been addressed.
The turbo seals are labyrinth seals, no nead for sel conditioners there. As for the bad rear main seal... well, there is only one way to fix this, and that is to fix the seal.
Originally Posted By: 05LGTLtd
Keep in mind that a synthetic 10w-30 wil have less VII than a conventional oil. Also lower noack and better teost. All good qualities for a oil cooled turbo engine.
This is also a good point.
There was another point made in this thread (but I blw the quote): that you have a flat tappet engine and thus want high levels of ZDDP.
And to bring it all together:
- the manufacrurer specced a straight 30, as he was afraid of the early VIIs failing. So the manufacturer obviously wanted a relatively high HTHS (even though the term HTHS wasn't in use by then) and a shear stable oil.
- but you do not want to viscous oil, as sometimes you cold-start the car on colder days.
- old turbos can produce absurd heat.
- mineral oils coke easily.
- a synthetic oil has less VII, higher NOACk, is less susceptible to termal degradation and oxidation
- you want relatively high ZDDP, so no mid- or low-SAPS oils.
If I were you, I'd look for an POA-based synthetic with european manufacturer certifications, especially MB 229.5 (shear stable VII and low NOACK) and Porsche A40 (includes a hot-shut-off test in a turbocharged engine to control coking). Taking into account the manufacturer prescribed a straight 30, I'd choose a heavy 0w-30/5w-30 or a lighter 0w-40, and the higher HTHS, the better. Most manufacturers just tate HTHS >3.5, but if we find something more specific, that is what we want. There are some o-30 and 0w-40 that have 3.68, some even 3.8 - which would be in the same range as a straight 30. All the protection you need, better cold start.
The two fully synthetic Castrol would be the first to come my mind. There are a few others, but if you want PAO, the air is getting thin, and Castrol would probably be the easiest to get.
