wemay
Site Donor 2023
Originally Posted By: dave1251
Originally Posted By: firebird72
thanks for the suggestions. im not really asking which brand or weight oil to use, more concerned about the turbo, ultrafanUK mentioned the concerns, a turbo has an oil seal around a shaft that spins very high rpms, im not sure if a HM oil will be good for that if it swells the seal.
the engine has great compression & doesnt consume any oil, also all other gaskets are new & the heads were rebuilt a few years ago with new valve seals, so the high mileage isnt needed for other gaskets & seals, its just the rear main seal that drips a bit.
if there is any question about the HM oil & the turbo i will just use a quality conveentional oil or maybe a blend & deal with the minor seal leak as i have for years.
This is my opinion. There are high ester content PCMO's such as Redline and Motul. There is no "caution" about using high ester content oils for turbo seals. HM oils are ISLAC GF-5/API SN certified and seal compatibility is tested for the certification.
This^. You will get no more seal conditioner than is allowed by API for SN rated oils. It may be towards the upper range of that spec but not more.
