High mileage Equinox 1.5T
Suburban Washington DC
Is this the engine that most people here avoid? It held up pretty well if it's the original. I'm tempted, just for the bragging rights and the experience.
GM 4 cylinder engines aren't that bad, yes they have some problems but if maintained with decent oil change intervals they last.
Bring a code scanner and post the codes, possibly a turbo under boost issue.
Looks clean, and you're the sort to be able to swap an engine for pennies. I say, go for it, I have no problem spending other people's money.
But I'm not sure that anything below about 400k has much bragging.
FWIW my wife's 2018 Equinox with the 1.5 FWD so far has been OK. Had the turbo wastegate solenoid replaced under warranty at 29,000 miles and the sunroof 'recalibrated' (whatever that means) after the bumper to bumper warranty was up at 39,700 miles for $100 at the dealer. So far it hasn't burned any oil and it gets pretty decent gas mileage. She short trips it occasionally but it has mainly seen highway miles. I change the oil every 5000 miles regardless of what the oil life monitor says. I replaced the OEM tires at 34,400 mil;es and the plugs at 56,100 miles. Nothing else.
These 1.5's at least come in our shop with oil on the dipstick, something the 2.4 of previous generation can't say. Along with the timing chain rattle that came stock on the old ones... gotta be better. But it is a FWD GM 4 cylinder still...
