I am trying to replace the circled bushing:
This is what the replacement bushing looks like:
One side of the bushing is "flanged" and larger. The opposite side appears to be rubber. In order to remove the bushing I think you have to push on the rubber side since it is the smaller of the two. Since it is rubber, I don't think normal press cups would work. I would prefer to not burn out the bushing if possible.
What is the best way to remove/install this bushing?
