This is courtesy of Helm Inc.(printing, binding and distribution of automotive OEM service manuals)
Considering restoring a classic car or just polishing up
your car? Here’s how to repair a paint chip:
1. Purchase touch-up paint for your car. (For the correct paint, see your Owners Manual)
2. Purchase a small amount of automotive clear coat.
3.Wash the area surrounding the paint chip and dry it thoroughly.
4. Using a small soft brush or Q-tip, clean out the paint chip.
5. Shake up the touch-up paint
6. Take a paper match and trim the non-lightable end to a point. Matches work well for applying paint.
7. Apply a small amount of paint to the chip. Try not to get any on the surrounding paint.
8. Allow the touch-up paint to dry thoroughly, then apply a layer of clear coat over the touch-up paint.
9. Allow the clear coat to dry then apply a second layer. You want to build the clear coat up higher than the surrounding paint.
10. Allow the paint to dry for 24 hours.
11. Using 1500-grit sand paper, lightly sand the area. Make sure there is no dirt on the car or the sand paper. This will cause scratches.
12. Using 2000-grit sand paper, sand the area again until smooth.
13. Finish the process using a fine polishing compound on a soft cloth. This will bring back the shine.
14. If you can still see swirl marks, try a car cleaner polish or a cleaner wax with a fine abrasive.
15. The paint chip should now be gone and very hard to see. Only you will know where it was.
Tips:
1. Always check your Owner_Manual and Service Manual before beginning any repair.
2. Don’t be in a hurry. Make sure the paint is 100 percent dry before sanding.
3. Only sand a very small area surrounding the paint chip. Don’t go crazy.
4. Sand only in one direction; do not go round in circles.
