Well.. I toppeed up my car with some prestone all makes and model bout a year ago and notice my car is runnin a lil hotter since..
long story short...
went thru Timmies drive thru on last wednesday, 3rd car. ( so wait time from start to finish is bout 5 min. )
notice the car went way above normal.. seems like 220F ( not sure as the middle mark is 90c and usually doesn't exceed by that much in stop traffic unless I sit in rush hour for 15 min. or so )
can't see any water leak under water pump ( but it's situated in a dumb place that doesn't give me access to see right under it )
water pump pulley is making some weird noise ( but was changed less then 2 years ago )
running 180 T-stat ( bout 4yrs old ) car usually is bout 171F while cruising along on the highway ( 1 mark before TDC 90c )
Any suggestion on a.) how to find out if it's the thermostat or not? I heard to do a boiled in water test to see if it opens and how large the opening is.. anyone know what it's suppose to be?
b.) I may do a coolant flush.. but it ran on dex cool, and been scared from all the post I read bout Dex cool clog.. any suggestion on other coolant? ( G-05?? And where to get in Ontario Canada )
P.S.
Its a 97 Bonneville SSEI 3.8L supercharge
P.S.S. EDIT= I also the car runnin a lil hotter then that.. and if I wait at traffic light and start accelarating, the needle will start to climb close to 90C ( TDC ) till I keep driving for bout 4 min. then it will start going back down.. but at times will sit just a lil higher then the 3/8 mark I'm accustomed to seeing it sit on
long story short...
P.S.
